Question about Compaq Presario Notebook
Internal modem on my lap top doesn·t work
After a restore sesion modem can not be connected. The messaje "AT # CLS= ? modem is ESS ES 56 CVM PI Data Fax Modem Voice" appears
  • 1 more comment
  • ingpueblito May 19, 2009
    modem had been working properly up to the restore sesion
  • Chris Hingee
    Chris Hingee May 11, 2010
    Have a look in Device Manager and check if the modem is enabled and working.
    If not reinstall the modem driver.
  • Chris Hingee
    Have you installed the driver for the modem?
  • 3 Answers
What type of compaq is your laptop? If it is a HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario v3000/v6000 series Notebook - HP has a limited warranty service. Also the F500 series is included. The wifi has disabled itself on these laptops and hp is aware of the problem. The wlan usually will not come back on after the computer restarted. Also they list some updates and trouble shooting to do prior to giving them a call. You will have to try the trouble shooting before calling them. The hp support will also make you go through some trouble shooting and if that doesn't work they will verify if your laptop series is eligible for the enhanced repair due to the hardware issues that they are aware of. Because of the hardware issue HP has extended the warranty from 12months to 24 months on the above series. Here are the websites:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277
and
http://search.hp.com/query.html?cc=us&lang=en&la=en&qt=limited+enhancement+programs&hpr=http%3A//bpr.hpordercenter.com/hbpr/M14.aspx
Posted on May 25, 2009
My 2006 BMW convertible top wont re tract. the yellow light comes on and nothing. the manual doesnt say want to do to fix...?
The convertible top is controlled by the Convertible Top Module (CVM II). This module contains the processing, controlling and monitoring electronics for the complete top operation.
The CVM II communicates with the General Module over the K-BUS for operation of the top storage cover and windows. The CVM II is fully diagnosable and contains fault memory for storage of monitored faults. Diagnosis is carried out over the K-BUS with the DIS or the MoDIC.
To put all of that "technical jargon" into plain English, If your convertible top is malfunctioning, you must BEGIN diagnosis by scanning your onboard computer network with the proper equipment.
Apr 26, 2012 | 2006 BMW 325 Ci
When i connect my usb E367 modem to use mtnonline, tells me that mtnonline.exe has stopped working and then says a problem has caused the program from working correctly, i am using Windows 7 Ultimate...
A flashing data light indicates it is trying to establish a connection with the exchange. This could be failing for a number of reasons.
There is a problem at the exchange, you will need to speak with us to resolve this.
· You are not getting enough power to your USB modem.
· Broadband has not been enabled on your line.
· Your USB Broadband modem has not been installed properly.
· Your USB Broadband modem is faulty (very unlikely, only suspect this if all other avenues have been investigated).
Hope this will help you out ................
Jun 21, 2011 | Computers & Internet
I am not able to connect through internal wifi(wireless) network device in my Toshiba Satellite L505D Laptop. I am able to connect net through a external USB wireless network adapter.What is the problem...
Locate the wireless switch and turn it on? if it is on you might need to reset the modem from your service provider. Just go and hit the reset button on the modem or turn it off completely. Power it up again and make sure that the switch is turned on if you have one for this lap top some are automatic.
The switch is usually located on the left or right front of the lap top housing in the front or on the keypad. You may have to push the FN key if the key is blue highlighted. Hit FN and press the wireless key if applicable. Make sure all is on and switched then reset the wireless modem or connection.
Jan 28, 2011 | Toshiba Satellite L505DGS6000 Notebook
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
How to connect my dell dial up modum to lap top
Your dial up modem needs to be ab external modem.
You can not use an internal modem from another machine unless you create a network and share your connection.
If you have an external modem then connect the modem to the available port on your laptop and let plug and play take over. If you do not have a port on your laptop and you modem has a serial port you will need a usb to serial adapter which you can get at Radio Shack.
Jan 09, 2010 | Ultra Computers & Internet
Hi i can not estublish the wir;ess connection betwenn the router and my lap top. i have 3come wireless router. however, if the network cable from the router is attached to the lap top i do get the...
Please enable the DHCP in your laptop's wireless network ip. If your laptop had a different network ip address for your wireless network. it will not support.! please let me know if there is any questions.
May 01, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
I was given a think pad 2647 and I can't get on the internet.
It may not detect it automatically. You will need to configure your dial up modem if you are trying to connect to the internet that way. Go into the network connections and go through the wizard there. It should ask you for the telephone number to dial for internet access so have that handy. If you don't get that box, you went to the wrong area.
Nov 19, 2008 | IBM ThinkPad T20 2647 Notebook
Lap tops modems
I can try ... for solving the problem....
Nov 10, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario Notebook Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
