Question about Ovens
Oven error codes
I have an aniston oven model: fz 1021p.1ix ne with an error code Er73 (or 13). Do you know what that is? Yours sincerely Gitte Rhilinger, Denmark.
SOURCE: Electrolux Wall oven E30EW75ESS
Same F23. Resetting the beaker seems to fixed it. Thanks to all
Posted on Jun 07, 2008
SOURCE: Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
Posted on Jan 28, 2009
  • 19 Answers
SOURCE: F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
Posted on May 09, 2009
fixyourboard
  • 310 Answers
SOURCE: GE Electric Range Model #JBP95A F1 and F7 Error Code
F1 is a common error code indicating a failure of the oven control board (aka ERC or EOC). Often these control boards have been discontinued, "no longer available" or are very expensive. We may be able to help and save you money.
We refurbish oven control boards at www.fixyourboard.com.
Posted on Aug 23, 2009
SOURCE: Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Posted on Nov 22, 2009
Hi probleme f7
Do a search on the internet for your oven's MODEL # and the workd manual. (Model # on mine is on the oven frame behind the door. Don't know about yours. Look around on it.) The appliance manual should be online.
In that appliance manual, it should list what the code F7 means, and what to do about it. For my oven, the manuals are available in English, French and Spanish! Hope your is online. Good luck.
Jun 06, 2016 | Ovens
Shows an F3 error. what is this error code
What make and model of oven do you have? Without knowing which oven you have there is no way to determine the error code.
Dec 12, 2015 | Ovens
I have whirlpool built in electric oven model RBS305PRS00.When baking sometimes the oven will cut off and display EO F3 is this an error code?If it is an error code what does it mean and what do i ne
This is typically the oven sensor that is bad. The sensor is the pencil size probe in the oven. They usually can be pulled out from the front. and have a disconnect clip. very easy to replace.
Nov 18, 2014 | Whirlpool Ovens
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
Whenever I bake at a temperature above 370 degrees in my model jkp90s, it gets a f9 error code and attempts to lock the oven door. Is this a common problem with this model GE oven? Is there something...
Hi jrsinister,
Error F9 has something to do with the lock switch. There two things that you can check to solv the problem. First, check wiring to door lock switch (the wire harness may be connected wrong). The other ne is to check for stuck lock switch.
Hope this helps.
Thank you for using FixYa.
Apr 05, 2011 | GE JKP90 Electric Double Oven
Jun 28, 2009 | Ariston Technologies Ovens
May 09, 2009 | GE JRP15 Electric Single Oven
Mar 29, 2009 | GE JTP27 Electric Double Oven
F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
Dec 21, 2007 | Ovens
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
