Question about Kenmore Refrigerators
Stop making ice
My cold spot # 106.53642300 stop making ice, led light, and switch working fine, water still come out from the front. i did not hear icemaker run (did not hear water run)
please give my some ideas, thanks
Ice maker and water stopped working, hear a clicking sound. We tried cutting power and starting again, it stopped making the noise, but we still got no ice or water, and after a couple hours started making...
the sound from the icemaker is coming form the water solenoid valve, which needs to be replaced. if your frezer is cold then the fan is fine, most are switched to turn off when you open the door so you arent likely to see it running unless you set up a camcorder in your fridge :-)
Aug 14, 2009 | General Electric GSH25JSXSS Stainless...
It stopped making ice but cold water option works fine. No clogs visible. Changed cold setting to 7 from 5. Nothing worked. just took out water filter, but can't see how that was the problem.
Put the filter back in . Pour about 1/2 cup of water into icemaker . If it dumps , then replace the water inlet valve . If it doesn't dump and the ice stays in the icemaker , replace the icemaker . Also , make sure the coils are clean of dust etc... Reset the controls back to normal or you could create water freezing in door (dispensor) .
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Jul 25, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Whirlpool Side By Side not making Ice, but water dispenser works
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Mar 15, 2009 | Whirlpool ED5VHGXM Side by Side...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
We had the same problem with ours. We held a hair blow-dryer to the end of the water tube for about four minutes, and the little ice plug just fell right out.
Aug 06, 2007 | Whirlpool GS6SHEXNL Side by Side...
No ice production
http://www.fixya.com/support/t158377-ice_maker_sotp_making_ice_red_light Barry, check out the above post, it will give you instructions on how to jump start it. Reply back if you cant get to it. Catriver.
Jul 08, 2007 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
