Question about Proxim Orinoco Ap-700 802.11a, 802.11g/b (8675-us2) Wireless Access Point
Ap 700 reboot suddenly
Seems like AP 700 booting in the middle of the day, so everybody disconnects.
And I ever experienced AP700 back to the factory defaults by itself.
  • kurdosman Jan 27, 2008
    anyone know to install the AP 700
  • 4 Answers
Danny_ostrander@hotmail.com if u want a solution for AP-700
Posted on Dec 01, 2008
  • 49 Answers
Device setting themselves on their own to default?  Sometimes power surges, thunderstorms causes all of these. Reconfigure devices and try to buy surge protector.
Posted on Oct 25, 2007
How to reset orinoco ap 700
See the AP700 Hardware Overview below.... while the router is on.. press and hold the reset button (hole) for about 10 sec, using a paperclip.. the simplest way to restore your default setting..39f23e8.jpg
May 12, 2010 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Engenius eap-3660 access points channels chashing.
This is a massive and expensive network, which appears to require a full signal and configuration audit. It's quite possible that many of your problems are stemming from the APs you have already deployed being situated in suboptimal and conflicting locations, which is an issue with three-dimensional wireless networks.
I really don't see your problems being debugged by anyone short of an experienced on-site wireless network technician. I'm saying this as a person who tuns a one-man company serving two rural communities with wireless internet service.
Sorry.
May 07, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Apr 17, 2009 | Aironet BR500
    Belkin 54g Wireless connection problem.
    This is more of an explanation then a solution, but to best explain what to do I have to first explain why this is happening. When you add security to a wireless router or ap you add extra envelopes to the packets of info being transferred, adding encryption to that makes it much slower because the ap has to encode all packets coming to you and un-encode all packets being sent to the Internet. In our time this happens very quickly, but in computer time I just described a lifetime. In addition if your signal is not 100% you might have packet loss "more slow down". Now the answer, in your ap setup pages you can setup wireless security, set this to Mac address authenication and add the mac addresses of all the network cards that have access to this ap. This is by far the fastest methiod of secure data transfer.
    Hope this was some help...
    Tim
    Mar 22, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
    Does the Symbol AP 3021 Access Point accept WPA encryption?
    on the info i could find it only supports WEP.
    but if your issue is to be more secure look up if it supports a sort of mac filter.
    this will only keep everybody out of your router but your signal will only be WEP encrypted.
    Feb 09, 2009 | Symbol Spectrum24 AP 3021 802.11b
    AP always restart
    I checked it out and it seems you don't have to manually reset/reboot it. You just have to log on to the AP, then choosing REBOOT after you are done, then the changes will that place annd you should be fine.  Note: due to the built-in internal directional patch antenna, repeater mode and WDS option do not apply in WH-5400CPE.
    I hope this helps you. Enjoy!
    http://69.64.87.53/airlive_fileserver/uploads/English/support/SD1218435928270.pdf
    Jan 02, 2009 | Computers & Internet
    Reset AP-700 failed
    Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
    Oct 30, 2008 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
    Ap 700
    If you have a wired router it should be plugged into that. The IP address of the Wireless Access Point is usually 192.168.0.50. When you see your Access Point page go to the setup option. Do the basic setup and then go to the Wireless Option. I usually put the dot in the WPA PSK part. That way i can put my own password in as long as there are no less than 8 characters. Click on apply and ok. If you need to get on the internet wirelessly then you need to connect using the password you just created. Let's hope this helps you out.
    Jan 27, 2008 | Computers & Internet
    How to extend the range of my MN-700 Base Station
    Hi Entry Level Extenders (or by their real technological name Repeaters) are chipset dependent and therefore guaranteed to work with Hardware of the same Brand. You can try to build your Own Extender. Buy two Access Points (AP) one of them has to be able to be configured as Client. Configure the client AP to communicate to the MN-700 and then plug the second AP to it and configure it as a regular AP. Put the concoction in the middle of the way between the MN-700 and the destination computer. Doing such an arrangement might cost a little more, and be a little bulky. On the other hand it would not cut the bandwidth into Half as Repeaters do. Otherwise may be this can Help. Extending Distance: http://www.ezlan.net/Distance.html Wireless Bridging: http://www.ezlan.net/bridging Wireless Segregation: http://www.ezlan.net/shield.html
    Feb 19, 2006 | Microsoft MN-700 Wireless Router
    Proxim Orinoco Ap-700 802.11a, 802.11g/b (8675-us2) Wireless Access Point Logo
    404 people viewed this question
    Top Proxim Computers & Internet Experts
    Prashant M
    Prashant M
    David Gust
    Don Eagan
    Are you a Proxim Computer and Internet Expert? Answer questions, earn points and help others
