Question about Vacuums
Little yello wj 528 steam just stopped - Vacuums
3 Suggested Answers
SOURCE: need to download a manual
You usually go to the manufactures web site
Posted on Aug 05, 2011
small6363
  • 18415 Answers
SOURCE: Instruction manual for Little Yello Steam Cleaner
what brand name is the model BISSELLL/ SHARK/HOOVER/?
Posted on Nov 20, 2012
What does yellow exclamation point light mean
YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
Yello steam mop does not make steam
The release lever is held in place by tabs molded into the base. You just need use a screwdriver or two to press the plastic tabs back and then push the release lever out. The new release lever can be just pushed into place and the plastic tabs will snap and hold it in place.
Feb 13, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Nov 20, 2012 | Vacuums
Little yellow steam cleaner wont work no steam coming out of nozzle
I have got a little yello steam cleaner there is no steam coming out of the nozzle wot should I do to be able to get this to work again if some one can help me please
May 06, 2012 | Vacuums
Need to download a manual for my little yello steam cleaner
Aug 05, 2011 | Vacuums
My shark steam mop has stop producing the steam to clean. I only get a little water to come out to wet the cleaning pad. Is it stopped up and if so how do I get the steam and water flow back
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
7
Sep 12, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Sharksteamer not steaming anymore
Change the type of water you are using...try bottled water...
heatman101
Feb 27, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steaming very little. The mop used to have strong bursts of steam, but now will steam very little. I use distilled water in the tank. Should I clean it with vinegar and water?
It will not hurt it to try and clean it...
heatman101
Dec 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Vacuums Logo
62 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
