Question about Canon Pixma iP2600 Photo InkJet Printer
Loading the paper
Where do I load the paper to print
    Sergeant:
  • 138 Answers
It should be in the back of the printer
Posted on May 19, 2009
Hello, I have a question about the HP 1312 all in one printer. Does it print on legal size paper and where do I load the legal size?
Yes, it can print on legal size paper. Do the following:
Lower the paper tray, and if necessary, slide the paper-width guide to the outermost position.
Fold out the paper-tray extender to catch paper as it exits the device.
Tip: For best results when loading legal-size paper, fold in the paper-tray extender before loading the paper to avoid a paper jam.
May 13, 2011 | HP Office Equipment & Supplies
Tip
Important!: How To Load Paper In Paper Tray Properly
In the printing process, paper jam more frequently occurs on bad paper handling rather than mechanical failure of the printer. So,to ensure that printing process runs smoothly please pay good attention to the following tips before loading the paper in paper tray of your printer.
Tips:
  • Align the edges of paper neatly before loading. Loading paper without aligning the edges may cause paper jams.
CONTINUE READING...
on Sep 19, 2012 | Canon Office Equipment & Supplies
Ajbennett@gvec.netI have a 5250 kodak printer and when I copy something the paper comes out gray with black lines down the side. It does print. Why is the paper colored and have lines on it?
You are possible loading the paper in up-side-down. Try loading the paper flipped over. A lot of kodak photo paper have bar-codes printed on one side for the printer to scan and verify you are using the proper paper for the printing job you assigned to it.
Apr 08, 2011 | Cameras
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
When i replace with new original 818 color and black/white ink cartaiges the ink status show as b/w full and color iswith"x" mark(no ink) and printer can"t take paper i also re load the driver software
If there is an "X" on the color cartridge indicator then there is a problem with it. If you have removed the plastic tape that covers the part that connects to the computer and you still have this problem then the cartridge is defective and needs to be returned to the store and exchanged for another that is good. Exchange the cartridge and install the replacement. This should solve the problem with the printer not recognizing a full color ink cartridge.
You mentioned that the printer cannot take paper. Please clarify what happens when you load the paper tray and try to print? Are you loading paper one page at a time using the external feeder or are you loading the paper tray full with paper before trying to print? If your loading page by page or filling the tray with only a few sheets of paper then try loading a bigger amount of approx 1/2" of paper. It is easier for the printer to grab paper when the try has a good amount in it. If it still will not load the paper when the tray is full and inserted correctly, please advise what happens when you try and print - exactly? Does the printer respond to the print command sent from the computer? Does it make attempts to load the paper and then fail and stop? Does it pick up paper and then show a paper jam? Does the printer do anything when trying to print from your computer? Answer these questions and I will help you solve this problem right now.
Sep 27, 2010 | HP Deskjet 3420 InkJet Printer
Unable to print on network it is showing offline or load letter. How to resolve?
I can help you with your HP Laserjet 4 printer problem.
Ensure the paper is loading correctly from the paper tray by reloading paper and printing locally.
If the printer prints locally, then paper loading is not the problem. Select your printer from the Control Panel > Printers list, right click and choose Sharing to re-setup printer sharing.
I hope that helps.
Aug 30, 2010 | HP LaserJet 4 plus Printer
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
Canon pixma 3100 keeps saying load paper and won't print
If you have paper in the loading tray and it keeps giving you out of paper message then the sensor by the loading hopper is not working and would need to be replaced.
9 times out of ten though you might want to clean the printer and make sure the hopper is not just jammed this happens when you put too much paper in there at one given time.
thanks
Sep 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Small problem with SCX-4200
I have the same issue but it resolved by itself.  I turned off the printer for a night and test again, it works.
Mar 14, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
109 people viewed this question
old marine
old marine
