Canon ir2016 error close cover/front and left cover
  • 28 Answers
SOURCE: CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Posted on Feb 28, 2008
  • 9 Answers
SOURCE: canon iR2016
most times eoo1 can be reset in service mode if there is no damage to fixing unit. 1) Enter service mode.
Press the operation panel user mode key, 2 key, 8 key and user mode key in this order.
2) scroll to "clear" and press ok then scroll to "err" and press ok.
if that does not work you can go back into service mode as above and instead of scrolling to "err" scroll to "all" and press ok. power off then on. doing this will clear settings service techs might have made but i've done quite a few and had no probs
Posted on Jun 14, 2008
  • 153 Answers
SOURCE: SYSTEM ERROR E805
you have a fan that is not working
Posted on Jun 08, 2009
  • 149 Answers
SOURCE: MY CANON COPIER IR2016 HAS FUNCTIONAL ERROR E805...
there could be a problem with the main fan and or the dc controller could be bad.
Posted on Jun 09, 2010
canontech
  • 1219 Answers
SOURCE: how can i solve error canon Ir2016 (download
Hi, you need to upgrade firmware from start. Download standby is message that appears when system is colapsed and when you want to upgrade firmware from service mode.
Posted on Jun 11, 2010
Hello My machine is Canon iR2016 and i have problem with Paper Jam. I have problem when I copying more then one copy and i got a problem sometimes in the first 10 copys, sometime at 20th copy... Error...
so, first, did you clean the vertical path roller? ( its a axis with two rollers beneath the paper registration sensor )
Second, when you open left cover, and paper guide plastic cover ( black ) there is also sensor flapper, that can be a quite of pain because slow reaction of spring on it. Apply wd40 on its spring and in left corner where he lays into bushing. To check flapper response, manually close the paper guide plastic, the sensor must be in middle position.
Also it can be the problem in paper pick up clutch and it needs to be cleaned or replaced.
But, also the problem can be separation claws in cassette ( metal claws that holds the paper ). From experience, the probably is sensor flapper or pick up clutch the problem.
Hope that helps!
If you need service manual or help, write on emma.servis@gmail.com
Jun 18, 2011 | Canon iR 2016i Black and White Copier
I have message error for canon copier IR2016 "System Error E019" Please help me on how to fix
E019 usually means the waste toner is full. The waste toner is, I believe, in the drum, so you'll need a new drum. The drum appears to be under the front cover. You might want to call your service rep. if you are not comfortable doing this yourself.
Mar 20, 2011 | Canon imageRUNNER 2016 All-In-One Laser...
Hello the problem is in my canon IR2016 showing
That means that fixing film ( Folie ) is worn out. Replace fixing film assy.
Jun 14, 2010 | Sharp AR-M350N Copier
My canon copier IR2016 has functional error E805
May 19, 2010 | Canon imageRUNNER 2000 Copier
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
"Close the front cover" sign even the door is closed already
On Canon copiers the close front door can be caused by other doors besides the front door.Try the fuser door an the left and the vertical transport door.Good Luck
Mar 27, 2009 | Canon imageRUNNER 400S Copier
Error E354 in copier ir2016
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Mar 26, 2008 | Kyocera KM-1505 Copier
CANON IR2016
Feb 27, 2008 | Canon PC-940 Black and White Copier
jasbo
jasbo
