Question about Advent Computers & Internet
Enter bios advent dt2410
Which f key to enter bios
1beertap
  • 32 Answers
SOURCE: How to Enter BIOS Settings in Toshiba Model: PS183C (Sattelite)
Press either the "Esc" key or "F1" when first turning on computer to boot up.
Posted on Jun 14, 2007
AvioriX
  • 689 Answers
SOURCE: entering the bios
There is 2 way to enter, you can use Toshiba HW setup for BIOS setting from windows. Alternately you can hit ESC several times after turn on the computer and hit F1
Good Luck
Posted on Jun 19, 2008
  • 341 Answers
SOURCE: start up problams
try removing the bios battery AND the rechargable battery for 10 minutes. Install both batteries and try again
Posted on Mar 18, 2010
SOURCE: bios password advent 7204 laptop
remove bios chip and replace it will work fine
Posted on Aug 27, 2010
nonontech
  • 4737 Answers
SOURCE: what key is pressed to
For most toshiba laptops, it's F2, but for some it's F1 or ESC or ESC and then F1 or F2. Honestly I haven't test it myself with your model but I hope one of these will definitely work, there are no other Bios key for Toshiba laptops other than i've mentioned here.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 21, 2010
Advent t9610
By pressing DEL can you enter the BIOS setup screen? If so, can you see the hard drive designated? It is usually in the initial screen where it lists all recognized peripherals, including your DVD drive and (hopefully) your hard drive.
Mar 14, 2014 | Computers & Internet
I have and advent 4211-b says ntldr files are missing i cant get on anything i want to reinstall vista but i cant get it to boot from usb please help
If you enter F8 just before the boot process you may be able to use the restore function otherwise enter the bios as you power on and set USB as 1st boot device.
Feb 24, 2014 | Advent 4211c Notebook
Power but no display
try going into bios blue screen press f2 or f10 or f12 on start up beep . change setting in video settings
  1. Watch for a "entering setup" message in the first few seconds after turning on your computer. This message varies greatly from computer to computer and also includes the key or keys you need to press to enter BIOS.
    Here are some common ways you might see this BIOS access message:
    • Press [key] to enter setup
    • Setup: [key]
    • Enter BIOS by pressing [key]
    • Press [key] to enter BIOS setup
    • Press [key] to access BIOS
    • Press [key] to access system configuration
  2. Quickly press the key or keys instructed by the previous message to get into BIOS
Oct 22, 2013 | Biostar Computers & Internet
My new dongle says no network when I put it in, whats wrong?
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html
Feb 14, 2013 | Advent 4211c Notebook
WHAT IS BIOS
BIOS is Basic Input Output System. On startup, before the windows screen comes on, you need to press one of the F# keys to enter the BIOS/setup screen. On my PC I have to press F2 to enter the BIOS/setup screen. The delete key can also take you to this screen on some PC's.
Mar 17, 2012 | Advent Computers & Internet
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
Start up problams
Mar 18, 2010 | Advent Netbook
Bios password advent 7204 laptop
I dont know which kind of bios you have but trying to take out/disconnect the bios battery might help.
/BS
Feb 28, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
136 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
