Question about Whirlpool LEQ9858L Electric Dryer
The heating compenent works, but drum won't spin
A few days ago, the dryer stopped working. When we press start on the dryer, the heating compenent heats up, but the drum just won't spin. We replaced the fuse for the motor on the drum and it worked for one cycle. When we tried to run another load of clothes through the dryer, it reverted to the heating component turning on, but the drum wouldnt spin... again... please help, thankyou
  • murnan14 May 19, 2009
    its not the belt ... as when the fuse was replaced, it worked for a cycle
  • 24 Answers
Have you checked the belt? That's generally the problem when a dryer stops spinning.
Posted on May 19, 2009
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
No heat from dryer
If a Gas dryer look first to see if igniter is coming on or if drum where clothes are gets hot or not.
Dec 10, 2012 | Dryers
I have a Kenmore 90 Series gas dryer model num 11074902200 that won't heat up. the drum spins and the heat will turn on for a few minutes then it stops heating up. I replaced the glow igniter but the...
The flame sensor is fine because it is powering up the ignitor. The dryer does heat a little. It can be only one thing: The solenoids are aged and weak. They work at first then the heat up and quit.
How to video
Service manual and more HERE
Sep 08, 2011 | Dryers
Heat works on dryer but won't spin... the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 28, 2011 | Kenmore Dryers
GE dryer is not working. a few weeks ago the spinning slowed and it sounded like the drum(?) was too heavy and grinding and then it just stopped spinning -my husband said that the three bath mats were...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 17, 2011 | GE DCVH515EFWW Electric Dryer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
My dryer is making a buzzing sound when trying to turn it on. Not working. Cleaned lint in machine. Also made sure the door is closed. This happened a few weeks ago, didn't work for a few days and then...
the buzzing noise is the motor trying to start try a test leave the door open with one hand press the door switch with other hand spin the drum at the same time have someone press the start button if your dryer starts then and when it is cool it is the motor replace the motor
Apr 05, 2010 | Dryers
Whirlpool LEQ9858L Electric Dryer Logo
699 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
