Question about Cobra R/C 3 Channel Big Shark Helicopter
Air shark 2 - Cobra R/C 3 Channel Big Shark Helicopter
This is the third time--I need the directions
Go to Shark's website to find the manual to download.
Aug 08, 2015 | Shark S3601 PROFESSIONAL STEAM MOP
My steam mop heats but doesn't steam. almost every time I used it, I used distilled water
Try filling the tank with pure white vinegar and plug it in, pump the handle to get the vinegar through the hose and let it sit for a half hour to dissolve any gunk that is built up, CLR works well for this also. Once it has sat, empty the tank and fill with fresh water.
May 04, 2015 | Shark S3601 PROFESSIONAL STEAM MOP
How to disassemble Shark Mop s3601? I took all
You need to remove the shark and power button sticklers. There is two screws in each. Once you remove the screws you slide the grey cover and remove 3 more screws holding the chrome piece. Now you can spread the cover open. I just replaced a torn hose.
Oct 10, 2013 | Shark Euro-Pro Professional Steam Pocket...
Shark steam mop troubleshooting
This is a bad sign. The heating element has either come loose or the thermostat has failed to shut the heater down. Dont use it anymore. You can disassemble it and see what the damage is but the smell leads me to believe that it is damaged to the point that is should be replaced. Check the warranty to see if it is covered.
May 17, 2013 | Shark Euro-Pro Professional Steam Pocket...
How do i take the Shark S3601 apart?
Water is spilling from the hook upconnection to the carpet slider.
Solution: It needs to replace an O ring in the junction.
Question is: How do I remove the junction?
Dec 30, 2012 | Shark S3601 PROFESSIONAL STEAM MOP
I have an air shark II and have no clue how to charge it ! there is a little wire that comes out of the controller and i plug it in and it just flashes red i let it charge for awhile and it still flashes...
The AirShark II has two ways to charge it. First you can plug in the USB cable into the chopper and then into your computer. The charging takes about 50 min. The second way is to take the little connector from the remote control and plug that into the chopper. The on button should be on the remote and the off button should be on the chopper. This also takes approx. 50 min.
Call us today for Virus Removal or other computer related issues
http://computech-ct.com
203-307-0452
Dec 15, 2012 | Cobra R/C 3 Channel Big Shark Helicopter
Cobra R/C 3 Channel Big Shark Helicopter Logo
Top Cobra Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Cobra Air Purifier Expert? Answer questions, earn points and help others
