Question about JBL Audio Players & Recorders
Problem connecting samsung to jbl onbeat awake
How to factory reset a JBL onbeat awake
Hello
For the JBL Awake
I just had the same issue and i found a way to solve this :
1. Unplug the power supply
2. Plug it back while holding the [ON/OFF] button
3. The screen shows “UP9” again
4. Do the update with the JBL Music app (I did it with my old iPhone 4s plugged on the 30pin connector)
5. Finish the firmware update ... until the app tells you to unplug the power before restarting the device
(Sorry for my bad English, i’m French)
Jan 04, 2018 | JBL Audio Players & Recorders
I recently purchased a JBL Flip 3 bluetooth speaker. Although I had no problem pairing my Samsung Galaxy 7 to the speak, I cannot pair the speaker to either my Verizon tablet nor my Dell Inspiron.
This usually happens when your speakers has hidden feature, try to look for for appear option. When trying the next time make sure that your paired device is not connected to it, as most probably it can not connect to two devices at time.
Dec 26, 2016 | JBL Audio Players & Recorders
How to open up the JBL onbeat rumble?
The power connection on my JBL Onbeat Rumble stopped working also. I could usually jiggle it to get it going but this wasn't a reliable solution. I note there were a few people online that have complained about this but no solutions or disassembly guides. With nothing to lose I set about pulling the unit apart to fix it... here's hoping it will help others:
1. Under the orange base rubber there are five screws. You need to carefully peel off the rubber to get to the screws. Also under the sticker on the input/output section there are two screws to undo.
2. See photo for positioning of rear clips. You might be able to use an appropriate tool to undo them. I used brute force to open the case and the rear clips didn't break.
3. There are two more clips and two screws at the front of the unit.
I don't know how to get to the screws - possibly you need to unclip the front of the unit and grille. I just used additional brute force which undid the clips and snapped the screw mounts. The unit was then completely opened up into two halves.
4. You can now get to the input/output section. There are four screws to undo before you can lift it out. In my case I could see a cracked solder joint on the power input so I re-soldered it as best I could and confirmed the unit was now being powered up reliably.
5. To reassemble, reseat the input/output board, clip the unit back together, re-insert the 5 base screws + 2 input/output screws, then glue the rubber back on (it might be sticky enough not to need additional glue). The snapped screw mounts don't seem to matter as the remaining clips are strong. Just shake out any plastic pieces to avoid rattles.
Jun 13, 2015 | JBL OnBeat Rumble Wireless Speaker Dock...
My JBL Onbeat Extreme has blown a speaker - I want to repair it but cant work out how to open it... there must be clips or screws somewhere
First you have to remove all of the bottom rubber feet, don't worry they are glued to the bottom, then with a sharp knife, remove the plasticdecal where the USB, AC and video plugs are. Pry it off from one corner then work your way all around, there you will find three more screws that will release the board. Good Luck!!!
Dec 20, 2014 | JBL OnBeat Xtreme Speaker
Jbl flip instructions
Either pair it through Bluetooth pairing, or use NFC (near field communications) if both devices have it.
All this is detailed in the instructions.
Aug 25, 2014 | Harman Kardon JBL Flip black
Jbl instructions
Took about 3 seconds on Google, including typing in the product name. These things are not difficult. You should try it. JBL OnBeat MINI Black JBL
Aug 15, 2014 | Harman JBL OnBeat Mini
Turns off on its own
I have a JBL flip and according to JBL it goes into sleep if not being used for a short period, like 20 minutes... No fix according to JBL... I don't know for sure if it's the same W/Jembe...
Jan 01, 2013 | JBL Jembe Two-Piece Entertainment Speakers
My new JBL onbeat xTreme when connected to my MacBook by Bluetooth and playing streaming from Spotify, keeps goimg into stand-by every ten minutes. It seems that it doesn't recognise that it is c
Same here. Streaming from Spotify from iPhone5..... every 10 minutes enters sleep mode. WTF? No idea how to get around it. Only FW upgrade I guess, if there any...
Dec 06, 2012 | JBL OnBeat Xtreme Speaker
Hello!!! Thanks for letting me ask these nagging questions. I bought a set of six JBL Home Theater Speakers.I did manage to have them connected and working. But I face a dilemma: How do I connect my...
You want to connect the JBL's to the yamaha using standard speaker wire. Get a few HDMI cables and run one from the blu ray to the yamaha and from the yamaha to the tv. To use the JBL's for watching tv, get an optical cable or coaxial cable (either will work) and connect that from the tv to the yamaha and you are all set.
Aug 20, 2011 | JBL Dual 8 3-Way Floor Standing Speaker...
164 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
