Question about Worldtech Devices Toys
Reciever lights up but quad copter doesn't work
P799 ufo unsearchable quad copter
Controller wont sync with quad after the steps. tried 25 times with no result please help
Mine too. Controller beeps when I push the lever up, and again when I put it down. That isn't described at all in the manual and it won't sync. At all. Any luck fixing yours?
gregsdouglas@gmail.com
Dec 15, 2015 | Protocol Dronium Remote-Controlled...
Quad copter won't lift off ground
Maybe battery is not accepting charge. I would try using a new battery.
Apr 20, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Intruder ufo won't lift up
If it lifts steadily but has no height check the battery may be at the end of its life.
HTH
Manta 4 channel rc quad-copter will not calibrate properly
Sounds like the axle is slightly bent and warped from the initial crash. Try replacing the axle and this should solve your problem.
Apr 19, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Nano copter instructions
How do I charge my Nano QX 18 Gram Quad-Copter?It came with a USB cord but I can not get it to charge.Do I have to go to a specific web site?
Jan 16, 2014 | Toys
Estes quadcopter does not fly up; only left, right, back and foward
How old is the quad? Maybe the gear shafts are dragging. (Not spinning at full potential)
Jan 10, 2014 | Estes Dart Quad Copter RTF ESTE4605
Manta Quadcopter will not take off
the instructions that came with the toy are wrong. you have to turn on the remote first, then plug in the quad. Push left throttle up, then down. It should work now.
Jan 04, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Leds stay on and do not blink,
Hi. I have the same issue.
RC has brand new batteries, switches on and see to work properly.
Quad is charged. But LED will not blink.
RC and Quad do not see to connect.
RC lights keeps blinking.
What happened ? As far as I know nothing unsual. I bumbed the quad slightly on the roof of the living room where I was fligh it. Nothing unsual. I landed it a bit roughly. Then it stopped responding. I assumed charge was empty but when I charged , nothing happened.
Dec 25, 2013 | Protocol Manta 4-Channel Radio-Controlled...
U817a loses connect to the remote control short after starting the droneflight
I would probably check to see if the crystal on the transmitter is connected properly and the wire in the reciever is clean and all the way in. Also if you're really close to a very strong power source consider moving away a bit (but your system is a 4ghz system so that shouldnt be a problem)
Dec 26, 2013 | UDI U817a 2 4ghz Ch 4 Axis Gyro Rc...
Copter is charged. it wont respond to the rc though
Turn on the remote control first then the heli the instructions are wrong
(I have the heli)
Toys Logo
Top Worldtech Devices Toys Experts
ray gallant
Are you a Worldtech Devices Toy Expert? Answer questions, earn points and help others
