Question about Rowenta Coffee Makers & Espresso Machines
How to start brewing coffee with a rowenta prelude coffee maker
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart coffee maker won't brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
VtToolMan
  • 704 Answers
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Posted on Nov 10, 2009
SOURCE: our coffee maker is only brewing half of the
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
Posted on Dec 16, 2009
  • 9 Answers
SOURCE: Coffee maker won't start brewing process
brew light is off
Posted on Feb 08, 2010
Set the timer to start brewing, i have always done this with no problem till now
Could be the brewing mechanism or the timer. However, if you get the action you describe on BREW NOW, I am inclined to think the brewer has failed.
Nov 10, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee Maker have problems starting and in some cases stops in the middle of brewing.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in brewing holes, refer to owners manual for cleaning instructions.
Jun 20, 2010 | Cuisinart DCC-1200 Coffee Maker
Can't find replacement for rowenta carafe..glass
  1. Rowenta Official Storewww.ShopRowenta.com Full Line of Rowenta Irons Get Your Rowenta Direct!
  2. Rowenta Irons & PartsSmallAppliance.com Shop the full Rowenta Line. Irons, Parts & Accessories.
  3. Rowenta Sale, Ships Freerowenta.irawoods.com Premium German Irons & Steamers Ira Wood est. 1918. Houseware store
Search Results Rowenta coffee pot replacements Coffee Maker Accessories at ... Compare prices on Rowenta coffee pot replacements Coffee Maker Accessories. Find store ratings & read consumer reviews on Krups Coffee Maker Accessories.
www.bizrate.com/coffeemakeraccessories/products__keyword--rowenta+coffee+pot+replacements.html - 120k - Cached - Similar pages
OR TRY EBAY!
Jun 03, 2009 | Rowenta Krups& Programable Coffeemaker...
Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Apr 06, 2009 | Keurig B50 Coffee Maker
Braun coffee maker starts brewing, then stops after a few seconds
ijustam1
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Jan 22, 2009 | Braun FlavorSelect KF 180 Coffee Maker
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
20 people viewed this question
Top Rowenta Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Rowenta Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
