Question about Magic Chef DU6500 Dishwasher
Magic Chef Dishwasher running time
Hi, We recently bought a home which has a Magic Chef Dishwasher (tri power sweep wash system). It seems to have an endless run time. The wash system seems to last about 90 minutes and over 2.5 hours before the load is finished. This is my first washer so I don't know if this is normal. Thanks a million for your thoughts....
SOURCE: Where do you put the rinse agent in a magic chef dishwasher ?
there should be a place in the door.
Posted on Nov 17, 2008
SOURCE: Magic Chef MCWC30MCG not getting cold?
You need to replace the Ptc unit attached to the compressor. Go to REPAIR CLINIC.COM and order the following part. 1206838 Ptc relay. They also will show you were it is located and how to replace it. Compressor tanks very rarely go bad. It is an $11.00 dollar part
Posted on Jan 30, 2009
  • 5 Answers
SOURCE: Magic Chef MCWC30MCG not getting cold anymore?
Replace PTC Starter and that is it. You can also try to open and clean contacts, I did and it worked.
Posted on Mar 30, 2009
Karthik316
  • 187 Answers
SOURCE: Magic Chef 20lbs hd won't agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Posted on Jul 23, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
I saw a thread that said someone had a user manual for a DU4500B Magic Chef dishwasher. I have one in the house I moved into and I'm looking to replace it, but there is no manual and I do not have the...
Magic Chef was recently sold and the company that bought them no longer publishs online the Magic Chef manuals any longer. However all built in dishwashers are a standard size and any new one will fit in the opoening of a pre-existing one
I'll give you this link http://mcappliance.com/magicchef.aspx and you could try to download the manual but i am 100% sure that all built in d/w's are a standard size
Aug 21, 2011 | Dishwashers
Water does not go into the dish washer during the wash cyle. This is a new problem on an existing Magic chef dish washer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Magic Chef Dishwashers
Hi, Just moved into a place with a DU4500B Magic Chef. After a cycle there is still a clump of wet soap in the main wash cup dispenser and the dishes aren't clean. Yesterday I tried putting the soap in...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 04, 2010 | Magic Chef 24 in. DU4500 Built-in...
I need an operators manual to know how to operate the dishwasher
I have a hard copy of the 7-page Dishwasher Guide for the Magic Chef DU4500B, but no soft copy. I will photocopy it and mail it to you if you send your postal address to me at worldbruce AT sbcglobal DOT net.
Table of Contents:
For Future Assistance 1
Safety Instructions 1
Operating Steps 2-4
Hot Water 2
Rinse Aid 2
Detergent 2
Loading Tips 3
Cycles/Options 4
Care and Cleaning 4
Storing Your Dishwasher 4
What Can and Cannot Be Washed 5
Common Questions and Answers 6-7
May 08, 2010 | Magic Chef 24 in. DU4500 Built-in...
Magic Chef DISHWASHER - mODEL du4k, STOPPED DURING drain cycle
I am assuming that the pump motor is bad, and since the unit is at least 15 years old (just guessing), we decided to wash the dishes by hand till after the holidays!!
Merry Christmas
Dec 09, 2009 | Magic Chef Dishwashers
DW will not drain
If the pump is running and it will not drain there may be an obstruction in the drain line like a small cherry pit or similar.  Disconnect the small drain hose at the inlet to the pump and check.
If the pump is not running it is a motor problem.
May 30, 2009 | Magic Chef CDB3100 - Multiple Color...
Leaky Dishwasher
The dishwasher was installed with a defective fill valve or the valve was damaged during installation of the dishwasher.
Jun 23, 2017 | Magic Chef 24 in. DC4000 Free-standing...
DIshwasher doesn't drain or fill
Hello annie8866,
First off.. unplug power and then reapply power to it for a little while to see if a power reset will put it back in the proper sequence.. next, check inside the base for a drain inlet and a filter/screen and clean anything you see out of it.. Then try cycling it without dishes to see if it will run thru a cycle and drain properly.. Its ok to add a cup or two of white vinegar during the wash process to remove byproducts of the wash from the inner components.. Make sure the drain hose is not clogged or kinked up.. Try these things and get back to me if it is still misbehaving..
Sep 29, 2008 | Magic Chef CDB6100 Built-in Dishwasher
Magic Chef DU6500 Dishwasher Logo
99 people viewed this question
Top Magic Chef Dishwashers Experts
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
