Question about Maytag Washing Machines
Blue streak stain appears on clothes when washed
Blue streak stains on white clothing. Maytag model no. LAT9604ABE. Blue stain ruins my clothes. I cannot remove them email me with a sloution at eagraw@telus.net Ed
    Champion:
  • 219 Answers
U may have a bad tub bearing and seal
Posted on May 21, 2009
My washing machine makes marks on everything
LG WM2101HW 4.0 cu.ft. Washer Stains clothes ruining ...
www.fixya.com > ... > LG > LG WM2101HW 4.0 cu.ft. Washer
... stains out with anything and they are ruining numerous items of clothing. ... stainson light objects ie making white marks on light blue clothes ruining these ... by greasestains from their front loader Kenmore. .... remove the agitator from a ...
Oct 19, 2015 | LG WM2101HW Front Load Washer, White, 4.0...
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
My LG Front Load washing machine is leaving black streaks and smudges on my clothing. These streaks and smudges are ruining my clothes!
There can be several things that can cause this problem. The most common are:
1. Fabric softener - did you switch brands lately?
2. Chlorine bleach - if added at the wrong time
3. A mechanical problem with the washer, like a leaky transmission leaking oil.
4. Rust staining, sometimes caused by the water being used in the machine.
Here is a link to a site that discusses this issue more in depth:
http://www.stain-removal-101.com/washing-machine-stains.html
Jul 26, 2015 | LG Washing Machines
My Kenmore Elite Top-Load Series 700 Washer leaves streaks on clothing. It looks like dusty powder. I use liquid HE detergent. It was a normal cycle of dark clothes, not heavily soiled or dirty. Also
THE stains on your clothing especially on whites are most likely due to a top seal failure on your transmission. transmission leaking oil. if the clothing affected or the stain can be removed with a solvent like gas, kerosene, paint thinner repair on washer will exed the value .... if the streaks or stains can be removed with a water soluble detergent then the stains are caused by the soap and or hard water deposits in your washer . then the solution to cut way down on soap usage in your washer and or running an acid wash (soap is alkaline acid will dissolve it . make sure not to over solvent your clothes and to rinse all solvents out completely . be careful !!!! a solvent soaked t-shirt bunched up and left in tightly sealed plastic bag WILL CATCH ON FIRE!!!!
Jan 22, 2015 | Kenmore Washing Machines
Washer makes stains on clothes
same thing happened in mines i put it though a hot wash with no clothes or washing powder it seemed to do the trick
Mar 16, 2012 | Maytag PAV2300 Top Load Washer
I'm getting small orange spots/stains on my clothing after washing them in my Maytag washing machine. it is a 2010 machine too. Any thoughts as to what could be causing the stains?
Unless there is a child's crayon or something similar causing it, then suspect that the agitator shaft seal, or the drum seal is leaking oil into the drum. Hopefully, there is still warranty on the machine. Good luck!
Jan 10, 2011 | Maytag Centennial MTW5800TW Top Load...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Stains on clothes after washing
This sounds like the infamous "Frigidaire Flaw" (they make some of GE's washers). The likely culprit is that the bearings on the drum's spindle are leaking.
To diagnose, call a repair man, or pull it out and remove the back cover. If you see brown streaks from the center spindle - that's it.
Repair is cheap if you can do the work yourself (inner and outer bearings), but $300+ for a technician
Feb 09, 2009 | GE WPXH214A Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Bleach stains
try putting your washer on the highest boil wash this sometimes will stop any of these problems from accuiring again
Jun 12, 2006 | Hotpoint WMM39 Front Load Washer
Washing Machines Logo
658 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
