Aiwa ad 1250 how to replace the belts - Audio Players & Recorders
2 Suggested Answers
SOURCE: replace capstan belts
(Unplug the unit before doing the following!)
Pull the top off (8 screws). On the back of each deck you will see a motor (silver cylinder 1.5"Diam x 1.25"Long) mounted to a removeable plate. It's kind of tricky, but... Loosen the bottom two screws securing the motor mounting plate (not the motor itself) to the rest of the deck. Then completely remove the top two screws, so the moter and plate fold away from the rest of the deck. With some care, you should be able to remove the old belt and slide the new belt over the capstan flywheel and motor pulley. Fold the motor assembly back into place and secure the screws. That should do it!
Note: I used a jeweler's screwdriver and needle-nose pliers to turn the screws on the motor mount. This is real fun with all the wires in the way, but it is possible. I Also pulled the screws on the power transformer, to move it, so I could get at one screw for deck #1.
BY THE WAY: I'm ready for new belts myself, and haven't been able to find a source, except in germany. Any ideas??????
Posted on Jul 31, 2009
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Aiwa AD-1250 When a cassette tape is inserted the spools do not turn; there is a whirring noise when ''forward'' button is pressed. Is it possible for me to repair this fault by opening up the machine ?
You need to replace the belts from the motor. From memory I think there are two. You will probably find that all the rubber parts need to be replaced, including the pinch roller.
Nov 04, 2010 | Aiwa Audio Players & Recorders
Need a replacement belt for Aiwa NSX-A777
CONTACT ANDREWS ELECTRONICS AT WWW.ANDREWSELECTRONICS.COM, THEN CALL THE CUSTOMER SERVICE LINE THEN TELL THEM WHAT YOU NEED.
Feb 24, 2009 | Aiwa NSX-A777 Shelf System
Rubber drive belts wanted for Aiwa AD-F810 cassette tape recorder
my aiwa brand cassete recorder model : TP-VS485 drive belt is broken, how replaced and where I can find spare parts
Nov 02, 2008 | Audio Players & Recorders
Aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Apr 20, 2008 | Audio Players & Recorders
158 people viewed this question
 Grubhead
Grubhead
