Question about Liebherr Refrigerators
Liebherr fridge freezer not working
Compressor working, fridge or freezer are not working
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
SOURCE: Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
Posted on Jul 22, 2008
SOURCE: liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Posted on Jan 04, 2009
SOURCE: How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Posted on Jun 08, 2010
My Liebherr Fridge / freezer has just stopped working. The light is on but there is no refrigeration, it is only about 4/5 years old. Help!
It is a technical problem more than likely but will require someone who can use a voltmeter. If the compressor is running then it is probably out of freon.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Mar 01, 2018 | Liebherr Refrigerators
Liebherr fridge freezer had Freon top-up to solve problem with warming up. Now there is a constant loud buzz when pump is running ( most of the time). Do I need to replace the pump/compressor?
If it ain't broke, don't fix it! If the compressor is working, leave it alone. Perhaps there is a metal panel or metal shelf inside that is vibrating from the compressor vibration.
Jan 16, 2013 | Refrigerators
Leibherr fridge freezer is not cooling in either compartment
Have you checked compressor running and condenser clean and clear
Apr 28, 2012 | Liebherr Refrigerators
Liebherr frige/freezer switching on/off by itself
its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Jul 30, 2010 | Refrigerators
Hope this helps.
Jun 08, 2010 | Liebherr Refrigerators
Liebherr Fridge Freezer fading door seal...
Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
Apr 06, 2017 | Liebherr KSv 4260
Our fridge and freezer seems to have turned off but the light is still on- we have a ten year old Liebherr KDVES4632, stainless steel-any tips, please?It is not blocked or obstructed at the back
Could very well be the compressor might have went bad. If nothing is running its the only thing it can be. Try turning both freezer/ refrig thermostats to their highest settings to see if compressor and evaporator fan is working.
Dec 15, 2009 | Refrigerators
Our liebherr freezer door seal has broken, should this cause the fridge to warm up.....5 upto 17 degrees?
All sorts of things can go wrong. Warm air will be sucked in and typically there will be water dripping from the cieling. The compressor will also continue to run .Will almost certainly get an ice build up on evep. plate. Suggest replacement as soon as possible.
Sep 16, 2009 | Liebherr KTS 1534 Comfort Compact...
Liebherr frost free fridge/freezer
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Fridge and frezeer not working
Liebherr embraco compressor....compressor fluid leaked while moving, what is the fluid? is it easy to replace?
Dec 06, 2007 | Liebherr KTS 1534 Comfort Compact...
Refrigerators Logo
51 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
