Question about Generic A13-MID 1.2GHz 512MB 4GB 7" Capacitive Touchscreen Tablet Android
TESOAR A13 NOT ABLE TO FACTORY SET UP
Why does it come on but it just stays on the screen that says android
The firmware is corupted, try to do a reset to factory default settings
May 05, 2015 | ZEEPAD 7.0 Capacitive Touch Screen 512M/4G...
I have my grandaughter tesoar tablet is frozen on the white screen with tesoar across the screen i need help
Hi, you need to do a factory reset!
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the volume + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
let me know how you get on!
Oct 18, 2014 | Tablets & eReaders
Tesoar tablet freezing on tesoar screen
Try this:
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
May 17, 2014 | Velocity Micro Cruz Reader R101 Tablet PC
I have a 7" Tesoar tablet and it worked great for a while and now the only thing it will do is turn off and on. When it's on it stays stuck on the white Tesoar screen.. Can I reset somehow? It will not let...
If a factory reset to default won't work, which it looks like it won't, I think one course of action is to open the back, disconnect the LI-ON battery, (it probably has a small, delicate three pin micro plug, so care is the operative word!), wait about 10 seconds or so, then reconnect it, and see if it then powers up properly.
That is what I did with my T310 when it went into a state of limbo.
Word of caution, opening the back will more than likely invalidate any warranty you have.
Mar 04, 2014 | Velocity Micro Cruz Reader R101 Tablet PC
Why wont my camera work on my brand new zeepad 7.0?
could be corrupted data or bad app,going to settings and reset to factory default that should fix corrupted data, if it still persists check for firmware updates in the settings, then check for app updates. if it still exists after that return back to factory for warranty repair
Dec 28, 2013 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
Download manual for my tesoar tablet
Hello, I am looking for a Tesoar Manual too - were you lucky in finding one?
Dec 01, 2013 | Tablets & eReaders
Tesoar tablet manual
need a manual for my tesoar tablet pc 8gb 4.0 android
Nov 24, 2013 | Tablets & eReaders
Open Questions:
See all Generic A13-MID 1.2GHz 512MB 4GB 7" Capacitive Questions
Generic A13-MID 1.2GHz 512MB 4GB 7" Capacitive Touchscreen Tablet Android Logo
94 people viewed this question
Top Generic Tablets & eReaders Experts
Trippy Tripp
ray gallant
Leslie Adrian
Leslie Adrian
Level 1 Expert
Are you a Generic Tablet and eReader Expert? Answer questions, earn points and help others
