Question about ViewSonic VX922 19" Monitor Flat Panel
I have a vx922, green light blinks but there is no picture.
    Problem Solver:
  • 7 Answers
Blinking about once a second? Switchmode power supply fault in the monitor.
Posted on May 29, 2009
Viewsonic VX922 19" - green
Since you hadd confirmed that the monitor is faulty with a swap then it seems that the input signal processor is faulty.
Only a signal test will confirm the fault in the stage , so check from the power supply section to see if the set has tripped off due to a protection- if so check the output drivers.
Jul 27, 2011 | ViewSonic VX922 19" Monitor Flat Panel
My VX922 will come on (for a few seconds) and the green power light starts blinking ? long-on, short-off. Turning monitor off & back on only repeats the above.
You need to open it up and inspect the inside for bad caps, burnt parts, etc, Post back what you see so we can guide you further, pictures will help a lot, see example of failed monitors here; http://s807.photobucket.com/home/budm/allalbums
Mar 19, 2010 | Computers & Internet
My viewsonic monitor is havind problem like constract& brightness is adjusting automatically what to do?
go to toms harwaere.com for viewsonic vx922 problems. Solutions for green power light blinking are there. Solutions say to replace the capacitors
Dec 06, 2009 | ViewSonic E70fb (Black) 17 in.CRT...
Blinking green light
this problem is adjust not screen resulation on your computer safe mode restert your computer and fress F5 go to safe mode
thanks Tareq
Sep 08, 2009 | ViewSonic VX922 19" Monitor Flat Panel
The blinking green light on VX922
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact Viewsonic to find out a Viewsonic service point.
See:ViewSonic - Support & Service
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Feb 26, 2009 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic vx922 Power circuit
It may be best to contact Viewsonic about a service manual for this unit and ask to see if that sell any parts for this model.
Sep 12, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic VX922 19" Green Light Blinks when booted, no picture
I have the same problem with my VX922 as do MANY others. The problem seems to be caused by leaking/bulging capacitors on the circuit board. The only solution is to replace the faulty capacitors either on your own (which is fairly easy if you're good with a soldering iron) or send it to Viewsonic and have them fix it.
May 21, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic Monitor problem, blinking LED light, no picture.
you guys......you don't have a software (driver, refresh rate, etc.) problem. When you first power up the monitor, do you get any display at all (ex, "analog input" or "No input signal")? Of course not - that's because you have a hardware problem with the monitor. Go here and watch the youtube video on how to take apart your monitor and find and replace the "domed" capacitors that have blown:
http://www.tomshardware.com/forum/247964-33-viewsonic-vx922-monitor-black-screen-green-power-light-flashes
Fortunately I only had 1 ($1.76 at Radio Shack). I replaced it in less than 30 minutes and my monitor showed "no input signal" upon powerup as expected because I wasn't connected to my pc which is full of all kinds of drivers and refresh settings, etc.
Aug 16, 2007 | ViewSonic VX922 19" Monitor Flat Panel
17" veiwsonic power blinking green
The flashing green power button is a well known electronic problem with this (and other) Viewsonic LCD monitors. There is a YouTube video (do a search) showing how to disassemble the VX924 and find out whether the problem is related to blown capacitors. When I took my VX922 apart I discovered 6 bad capacitors out of a total of 7 on the power supply circuit board.Only recommended for those handy with a soldering iron.
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic VX922 19" Monitor Flat Panel Logo
597 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
