Question about Nintendo DS Console
DS power problem
Hi I have recently been given a broken nintendo ds, the cable from the bottom screen to the top screen is completely broken and there is a little black wire that is broken.  I just wanted to know if i replace the cable from top to bottom and reconnect the black wire, so you think the ds will power up again.
At the moment it just flickers a white screen at the bottom and then turns off
  • 709 Answers
Hi Nerts,
These cables or ribbon cable and wire connects directly inside the upper LCD monitor. it is not feasible to replace these wires only.  I suggest you see about getting a replacement upper LCD screen which will give you the wires you need and a new screen to boot. Another porblem is the case itself is very hard to disassemble.  You will come near destroying the case to ge to the lcd.  You must disassemble the unit fully and put the correct curl in the ribbon cable to get it to fit right. In short, the price being what it is for a replacement LCD, and the trouble you have to go though to get this problem fixed, It may not be totally worth repairing. If you dont care and wish to do a repair, then my wishes for luck are with you.
Posted on Oct 18, 2007
Taking cover off nintendo ds lite
Are you talking about the back cover or front cover?
Either way, before starting you are going to need two things: A tri-wing screwdriver and a Philips screwdriver.
To remove the BOTTOM COVER, you must take off the stickers covering the screws and remove the screws. 001e10e1-317e-4bb5-97cd-230a82f77aaf.jpg
Then, carefully pry the back off, revealing the motherboard inside.
To remove the TOP COVER, you must take off the stickers covering the four screws in the corners of the INSIDE top screen. Unscrew them and gently push the inside top screen down until its about half a centimeter apart from it's backside. Then pull the backside off and you have it open.
If you wanted to open the DS completely, like have it in half, you should first open the BOTTOM COVER and remove the motherboard after disconnecting it from everything attached to it. Then follow the steps given for removing the TOP COVER and slide the ribbon and cables sticking through from the TOP to the BOTTOM back to the TOP so that they are not sticking through and won't be damaged when you take the DS apart. Then unscrew the power light and voila! The DS should be separated.
May 31, 2014 | Nintendo DS Lite
My Nintendo DS top screen is completely blank
you need a new case and top LCD as the cable running through the hinge is fragile and has obviously been broken. Ebay should provide you with spares required and youtube for video's on how to do the job
Jan 28, 2010 | Nintendo DS Console
My ds will not turn on
It sounds like one of you're screens has broken. What you have discribed is generally what happens one either the top or bottom LCD screen has broken.
If it is the top screen the bottom screen will flash for 1/2 a second and the DS turns off.
If it is the bottom screen the DS should still turn on but with no reaction from the screens. (the Ds will shut down immediatley after turning on)
Sep 17, 2009 | Nintendo DS Lite Console
Ds lite
sorry to say that your top screen needs completely replacing if it is doing as described!!
the bottom screen and the touch screen are seperate, jus mounted on top of each other, so if the picture works on the bottom then the bottom screen is fine just the touch screen is broken. again i think if the cables/ribbons are in correctly and it isn't responding then it will need replacing!!
Jan 29, 2009 | Nintendo DS Lite Console
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Jun 26, 2008 | Nintendo DS Lite Console
Ds Lite bottom screen flashes then shuts down
Not necessarily. When the cable to my top screen became partially torn, it prevented the DS from powering up. Instead, the green light briefly lit up and then went out and the machine stayed off. I can only presume that feedback is required from the screen. As for the bottom screen, I'm unsure of how the DS behaves when the screen or cable is damaged.
Hope this helps.
Jun 07, 2008 | Nintendo DS Lite Console
Bottom screen scrambled on nintendo ds lite
This option is only suitable for out of warranty devices as opening it violates the warranty.
Open the device following this info:
How to dismantle an Original Nintendo DS.
If yours is the NDS Lite, just find this video in youtube:
"Disassembling Nintendo DS Lite"
The bottom screens have 2 wrap wires, one big and visible, that is the screen cable, the other is small and not so obvious and this one is for the touch screen and you dont want to get it broken.
The cable connectors release the cable by lifting ot pulling the brown or black lock and be sure to remember how it was connected so you can know the right position of the cable when connected right not having any problem with loosen cables before you finish.
Good Luck...
Dec 16, 2007 | Nintendo DS Lite Console
Here is a guide to dismantle an original Nintendo2.gif DS:
How to dismantle a Nintendo DS.
If yours is the NDS Lite, just find this video2.gif in youtube: "Disassembling Nintendo DS2.gif Lite"
And after opening it you can do your work. Make sure the flexible cables connecting the top screen part of your DS are well in place and not broken. Your problem may be only a loosen cable but in case the cable is broken you gonna need a replacement. Be careful not to damage the screen or other sensitive electronic parts on your device and you will be on your way.
Good Luck...
Dec 01, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
85 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
