Question about Canon PIXMA MP780 All-In-One InkJet Printer
The printer drags the blank paper to the right side of machines then jams
    Sergeant:
    Champion:
  • 240 Answers
Try to rearrange the paper on the tray or add some paper to it..maybe the paper pick failed to pick them on time ..that'a why it give a jammed error..
Posted on May 19, 2009
Can't print pictures from my laptop. The printer always says paper jam but there isn't one
"Paper Jam" issues are common with printers. They most often occur right after there has been a paper jam. Most people (not necessarily YOU), don't take the time to read how to properly clear a paper jam in their printers and often yank the jammed sheets backward thru the paper tray. Most times you should remove the cover in the back and pull the jam FORWARD out the rear, or if the jam made it close to the output tray, then FORWARD thru to the output tray. Pull sheets backward can cause two issues. It makes tearing the paper easier. This can result in tiny pieces being caught in places where the printer detect them as a jam. The other issue is that pulling backward can damage the feed rollers that pull the paper into the machine, as well as the mechanical sensors that detect paper jams. If you cannot find ANY shards of paper in the machine, you may have printer damage that results in the jam indication.
Oct 10, 2015 | HP Computers & Internet
Xerox XD100 paper jamming every time.
The fuser is the problem. Most likely the fuser will need to be rebuilt or replaced.
Google a business called The Parts Drop. they have either the parts or the unit.
You may just have to take the fuser out and remove a badly jammed piece of paper in that module.
Shut the machine off for a half an hour. Remove the back cover. You will then see on the left side a black plastic bracket with 3 plugs on it. Disconnect those 3 plugs. Then open the right side door and toward the top is the fuser. It has yellow caution HOT labels on it. There are 2 silver phillips screws holding it in. Remove the screws and then remove the fuser unit and see if there is a paper in there. There are 2 screws that you can remove and the fuser will kind of fold open to inspect for bent fingers or one out of place.
Mar 30, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
ERROR CODE 6A00
Error 6A00 usually refers to a problem with the purge unit -at the right hand side of the machine, under the ink cartridges when in their home position. If you have had paper jams and removed the paper, sometimes a pice of paper gets torn off and when the printhead homes , drags this paper to the right and blocks purge unit. Open lid when machine is on to free printhead. Unplug printer then using a torch have a look inside for some torn paper (often this will be black as it is soaked in ink).
Please rate my response!!
Jan 31, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My printer is dragging the paper at one side then jamming. What could be the problem?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
pow-e-r-21
Jun 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
What is error code 6A00
Its a position error.
May 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper not feeding on the left hand side of our lexmark 5100
open the backdoor and try to move the rollers in upward direction...if the roller on the left is hard to move then..replace the machine.
Nov 25, 2008 | Office Equipment & Supplies
Paper goes in squint drags to one side and jams
In my experience the usual reason for this is something (obstruction) in the paper feed. Make sure you have a really good look right down inside the paper path as quite small objects will stop a correct feed. The fact that it is one side makes me thing something is in there. I have serviced printers before with coins, paperclips etc that have found a way in.
Nov 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Brother printer, paper inside, but I do not see paper inside.
PAPER JAMMED INSIDE THE MFC
1. Remove the Jam Clear Cover located in the back of the machine..
Squeeze the plastic tabs located on the right and left side of the cover
and pull the cover off.
2. Remove any paper you can see jammed in the machine. If you cannot
remove the jammed paper from the back of the unit follow the in
structions listed below for reinserting the cover and then continue to Step 4.
3. Re-insert the Jam Clear Cover. The top of the cover has a slotted
opening in the center approximately 1/4 inch wide. Hold the cover by the
plastic tabs located in the front of the cover on the right and left side and insert the cover into the opening until it securely
clicks intoplace (both sides).
4. Open the scanner cover by pulling up on the lower right corner of the
cover until it locks into place.
5. Remove the jammed paper. If the paper is jammed underneath the print
head, unplug the machine from the AC power outlet. Gently move the
printhead to the far right side of the machine (the "home" position) and
then remove the jammed paper.
6. Lift the scanner cover to release the lock and then gently push the
scanner cover support down and close the scanner cover.
To test print the Help List by pressing Menu/Set, 6 (Print Reports), 1
(Help List) and then Black Start. The Help list should begin printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Paper jam
After changing my blank ink tank, I have the same problem. Finally discovered that it was not fully clinked in. Once it was push in till it clicked as per instructions, the printer is printing beautifully once more.
Dec 06, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
