The screen remains black, laptop won't boot, fan makes a low noise
Laptop connected to the mains, when turned on fan starts up, no bleeps, fan does not step up like normal boot up, nothing on screen, remains black. Please help.
    Master:
  • 785 Answers
Try test an external screen to the computer, if you got it working, you have a broken backlight
Posted on Jul 02, 2014
  • 624 Answers
SOURCE: Laptop amkes a beep sound but doesn't boot
Hi Saniple, more than likely those are beep codes and should give us an idea of what is going on. Typically there is a specific pattern of long and short beeps. If you can identify them for us we can start the troubleshooting process
Posted on Feb 02, 2007
kikoksky
  • 119 Answers
SOURCE: laptop boots up intermittently or screen freezes
basing on the information you have given here are the possible solutions:
remove any external device connected to your system (printer, external hard drive and others) if removing this does not work and still gets a blank screen with blinking cursor try to go to safe mode with networking. if successful try to download the driver for your video adapter.
when you try to start the computer , do get anything on the screen like a logo? when does the blank screen occurs, is it during the turning ON of the computer or during the windows xp logo appears on the screen?
a blank screen could be caused by the following: defective video adapter, corrupted video driver, defective memory, unknown device causing the issue like the hard drive, optical drive or other peripheral installed inside the computer.
try also using an external monitor
Posted on Jun 13, 2008
Pyrhyc
  • 2028 Answers
SOURCE: help on my fujitso siemens MS2212 please...
The clicking is from the hard drive. This clicking , along with the error op system not found, indicates that the drive has crashed or failed. You will have to replace the hard drive.
Posted on Jun 25, 2008
SOURCE: Black screen on boot
I have the same problem with such model. I use it about 1,5 year. I think that is manufacturer deffect =(. It's woodo magic, but if i want to boot up my notebook i press "FN"-key end F2,F3,F4... ect. Sometimes it helps. =)
Posted on May 25, 2009
SOURCE: my everex stepnote wont turn on, fan runs but it wont boot
I have a Everex StepNote Laptop VA4101M. Model Number VA250W. I can turn the power on the laptop but the screen is black. I have already try taking the battery out and the power cord out and nothing.WHAT DO I DO?!?
Posted on Sep 18, 2009
Laptop powers up light comes on but doesn't seem to boot up & screen remains black?
is it bleeping?try ram?is the fan running?if not clean it could be over heating.
could be prosser over heating try new heat paste.
Aug 10, 2014 | Samsung R610-64G Laptop
Problem with Samsung R530 laptop screen.
Laptops do not fair well if liquid was spilt, and it does not take much. Remove main battery and turn on, if okay! battery needs to be replaced, next remove ram one at a time and power up making sure you always have one in the laptop, last! hook a spare monitor to the video output usually on the back, if okay! the LCD on the laptop has a bad inverter board, or defective backlight behind the LCD. Now if both show the same symptom it is the Video Graphics Card usually built into the motherboard.
Mar 19, 2012 | Samsung R530 Notebook
I have a laptop sony vayo . it was working fine till started to make a shrieking noise . i turn it off ( from the start button -the only way it worked ) and then tried to turn it on . the screen remain...
Check the fan on the bottom and make sure nothing is in it. Then press and hold the power button for 30sec.. Then turn the laptop back on once it starts, press F5 during the bootup to run diag
Jan 01, 2011 | Dell Studio 1737 Laptop
Having trouble turning my laptop on at the moment,the light comes on and it makes the sounds as though its starting,but the screen remains black.... On the odd occasion I have managed to start it I have...
problem must be with the fan or HDD because these are only two internal devices which does mecanical job inside.
Sometime overheating of CPU or the malfuntioning of RAM make noise thrugh the system speakers.
Apr 20, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
HP NC6000 boot failure.Fan starts but quits after 10 secs or so.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 22, 2009 | HP Compaq nc6000 Notebook
Compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
Apr 06, 2009 | HP Pavilion dv6000z Notebook
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
