Question about Microsoft Windows Vista Ultimate Edition
Winload.exe problem I cloned my vista hard drive. when i boot the hard dirve, it shows that the winload.exe is missing or corrupt. what can i do?
    Master:
  • 118 Answers
Is this ur oprating is on other than c:\ drive if yes then then u r not able to do to stop this error simply move ur data then install on the c
: drive then after u can create the clonr without error
please vote for me
Posted on May 19, 2009
\windows\system32\winload.exe missing or corrupt 0xc000000f for toshiba
This is usually a fatal error.
The hard drive has either a damaged sector or the windows file is damaged/missing. Try pressing F8 just before it tries to boot and select repair or restore.
Dec 26, 2013 | Toshiba Satellite Computers & Internet
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
My Acer Travelmate 5720 is stuck on the Windows Boot manager screen
Insert your boot disk and select new OS.
Follow the prompts including format of disk.
Jun 14, 2017 | Computers & Internet
Need help to fix hard drive I keep getting file is missing winload.exe I can't even get it to boot I need command window
we find your PC is not as healthy that some files are missing so i hope this can help you in a way to re-install Windows Operating System . install windows on Drive C partition only and stay Drive D as ease ,
Jul 15, 2011 | Computers & Internet
My laptop is saying i need to insert windows installation disc and restart comp file windows /system32/winload.exe status oxcoooooof info this selected entry could not be loaded because the application...
your boot record is corrupt..
get the recovery disk or install disc
then reboot and boot the install disc
the first screen has a "repair startup" option
goto there... it is all then obvious
Jan 21, 2011 | Computers & Internet
When i start up my computer it goes straight to boot manager and gives an error code file\ windows\ system32 \ winload exe,,, status 0XC000000F file missing or corrupt, what is the issue please, system is...
The problem you have is with the system boot files. There is a corrupt file and that is stopping the system from booting.
Press F8 as the system starts up, that will let you into the special boot menu and hopefully will give you the option of repairing your system. The timing can be quite tricky as there is only a very short time window. Trying a few times should get it.
Hope that helps.
Nov 21, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
My Computer Isn't Starting Up.
check with another Signal cable for hard disk
please attach only 1 hard disk no other drive
if same problem persist then boot from os bootable cd ,go to repair option
then run chkdsk /f utility
If still not then please reinstall your OS with repair option
Mar 14, 2009 | Computers & Internet
Acer 5520 notebook startup issues
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Dec 23, 2008 | Acer Aspire 5100 Notebook
I/O error. HP 1720n won't boot
Run diagnostics on the hard drive (Normally provided either in the F8 or F12 boot menus) and se if you get a failure.
If the drive passes diagnostics, boot to the Vista DVD and run the repair option. (Note: you may have to the Vista repair process 4 or 5 times if there are multiple errors to be resolved)
Sep 13, 2008 | HP Pavilion a1720n PC Desktop
Microsoft Windows Vista Ultimate Edition Logo
247 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
