Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Remove top cover from wmf760 - Hotpoint Aquarius WD63 Front Load Washer/Dryer
Aquarius +WMF760
Did you try unplugging it for at least one minute to reset the electronics.
Apr 28, 2014 | Washing Machines
Hotpoint WMF760 fills with water but doesn't move through programme
Bad motor/ DC power inverter control assembly. My suggestion is don't buy electronically controlled washing machines. They're designed to stop working and for corporate to sell you parts and service again and again and again, until you go buy a rebuilt second hand fully electro-mechanical good ole reliable mechanical top load washing machine.
Feb 07, 2014 | Washing Machines
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
I have 'somehow' removed the tension spring that holds my washing machine seal in place... and i cant get it back in place. HELP!!! The model is hotpoint wmf760.
If you are talking about the door seal spring clip and you have difficulty in getting it to slide back in it's grove use a bit of washing up liquid in the groove and the ring. Is it not adjustable?
Dec 30, 2012 | Hotpoint Washing Machines
My hotpoint aquarius+ wmf760 is flashing d-05 whats wrong
The black rubber ribbed pipe squeeze it afew times. Unblocks the pressure switch.
Oct 09, 2011 | Washing Machines
The wash dial on my hotpoint wmf760 is not selecting
The knob needs to be removed and the knob and the mating part will need to be replaced. The teeth on these parts wear off with time. There is a clip on the back of the knob that pulls off this holds the knob on. Then the mating piece will pull out. Eneter your model # at www.appliancehelponline.com for diagrams and illustrations. All parts come with installation instructions.
May 03, 2010 | Washing Machines
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
21 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
