Question about Kitchen Appliances - Others
Scotsman ice machine mv600
High pressure
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Posted on Nov 05, 2009
  • 129 Answers
SOURCE: Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
Posted on Feb 25, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
  • 7 Answers
SOURCE: Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Posted on Aug 23, 2010
Scotsman ice machine slow water fill
Check to see if there is a water filter inline if so then change it. If not then check where the supply water line is hooked up to the machine pull line off and turn water on to make sure you have good water pressure. if you have good pressure then pull the water inlet valve and take it apart to make sure it is not stopped up with trash and that is it.
Mar 12, 2015 | Scotsman CU1526SA-1A 150 Lb Self-Contained...
Machine is off and condenser fans are still running why?
Is the wiring correct? Fan runs when condenser is hot / high pressure not just when compressor runs so check condenser sensor.
Apr 22, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Mv450 scotsman high pressure
Check to make sure the condenser coil is clean, fan motor is running during freeze cycle. High Ambient temp, Ventilation, The higher the temperature entering the condenser coil the higher the head pressure. Fan motor failure, pressure switch failure. The cut out pressure varies 400, 450 or 500 PSIG. Water supply failure. not enough water running over the evaporator plate will cause high presser.
Jul 30, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman cme456as-1a
Pull and clean water level switch. Check to see if water solenoid is getting power to it if so check to make sure you are getting water through it. FIRST check water filter make sure its not stopped up. if that is clear check make sure water line is not kinked. If your unit is not getting water then the unit will run high pressure and lock out on refrigeration.
Jun 14, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Can`t get scotsman cme250 to work properly. either doesn`t make ice or won`t harvest ice. when cube size thermostat is turned up so it makes ice it takes long time to start forming cubes. electrical...
The problem could be a series of things beginning with ambient temperatures too high, fan not working properly, if water cooled there could be a problem with that also. As a technician I would first look over the condenser and make sure air flow is proper and then attach my gauges to see the suction and discharge pressures. I have found many restaurants that keep their ice machines in the hot kitchen where it creates high ambient temperatures and allows grease from the grill to collect on the condenser blocking air flow. Yes under charged is possible or over charged but the best and most effective route is to call a Scotsman Certified Technician. I have worked on Scotsman's and they are very tricky to fix unless you know the process of event. If water is not pre-filtered there is a chance that the water control valve may be stuck open allowing warm water to continue flowing causing these symptoms. Here Is a=> Scotsman CME250 Ice Machine User Manual If unable to find these simple checks above or from the manual and still having problems it will need to be time to call a Technician. If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) Tell me what you find and please don't rate me if I was unable to solve this from here. I am here to help you up and to the point of calling Scotsman for addition help. Thanks, Sea Breeze
Jul 15, 2011 | Scotsman Ice Machine, Cuber, 1825 lb....
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
High press light is always on, what does that mean?
you may have a high pressure fault due to poor air flow over your condensor coil, check it and give it a clean. also check your condensor fan is running properly.
Jun 03, 2009 | Refrigerators
Kitchen Appliances - Others Logo
52 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
