Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Delonghi Magnifica Makes creaking noise when preparing brew unit
My Magnifica is still working fine. It just makes this creaking sound, like it needs some kind of lubrication. I opened the case and looked inside but haven't delved further into the machine. It started making this sound a few months ago, am not sure what it is or whether I should be concerned about it.
The unit is clean and still prepares coffee fine. I am wondering what to do.
These machines do need to be lubricated every so often. First, buy some food safe lubricant, e.g. here. Then, turn the machine off, open the front door, and remove the infuser. There is a holder connected to the machine by two hex screws. You may remove this (or even just leave it on). Now attach a long tube to the lubricant (should come with the can) and spray lubricant on both sides of the vertical screw that moves the infuser up and down. Give it a few good sprays on both sides of the screw, up and down, and that should solve your problem.
Posted on Jul 01, 2009
  • 1 more comment
  • John Hansen Mar 02, 2013
    Timbo984 is correct, but I would add a caution. Don't over lubricate the vertical drive screw. Apply the lube very sparingly, as drive screw friction will increase with too much lube. Also, a lot of the noise is probably caused by the motion of the holder against the adjacent surface. When you remove the holder, clean it well, and also clean the adjacent surface. You will find that residue has built up behind the holder.
  • Brian Keating
    Brian Keating Feb 27, 2015
    timbo984's answer worked perfectly for me. I used a variant on the lubricant linked above which was in a tube, not an aerosol, and used a pastry brush to apply it to the screw. Instead of screeching, my 6 year old Delonghi now purrs like a cat ??
  • Andrew Battistella
    Andrew Battistella Jan 26, 2016
    Can someone please add a pic of what exactly I should be lubricating...please...
  • 68 Answers
The mechanical parts are not properly tight, because of the vibration this will cause loosening to the mechanical parts (erg.screws).
Posted on May 19, 2009
Hi, Is your creaking sound like a one time sharp cracking sound, like something snapping, during the start and end of the brew cycle? I'm hearing that on mine too.
Also is the white strain mark on the brew unit normal? Picture: Delonghi Magnifica Makes creaking noise when prepa - 10_29_2011_5_16_45_am.png
Posted on Oct 29, 2011
When i turn on my delonghi magnifica pronto on its says insert brewing unit but its already in plus it makes a really loud noise when i turn it on
Sounds like the brewing unit, or infuser, has not been properly seated into its holder. Are you sure that the two red retainer fittings are in their snapped out positions? See page 16 of your owner's manual.
If the infuser has not been properly seated it could cause a loud noise when the servo drive tries to raise the unit into its brewing position.
Sep 04, 2014 | DeLonghi Coffee Makers & Espresso Machines
Squeaking delonghi magnifica
Take it apart and clean it properly plug use sileco to lubricate for a longer use water heat coffee all of these make machine to fail
Keep service as importance
Jul 09, 2014 | DeLonghi Magnifica 3300 Espresso Machine
Unable to remove infuser, no warning light, reset multiple times, brews coffee fine
You should go to test mode and try moving infuser up and down to position when you can take it out it needs some skill of timing. After that you need to disassemble infuser completely clean it up and lube with special food grade lube. Also there could be a problem with transmission kit that cause this problem.
Mar 22, 2014 | DeLonghi ESAM3300 Magnifica...
Delonghi Magnifica EAM3400 When using pre-ground coffee I get the message; Grind too fine, turn steam knob. I do, but nothing changes. I pull out the diffuser, clean out the coffee, try again with beans -...
That is the reason the old owners gave it to you . You have to change the circuit board for it and it is as expensive as a new unit plus the labour and shipping .
Oct 30, 2013 | DeLonghi Coffee Makers & Espresso Machines
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica After heating up, Unit kicks off and readout says "insert brewing unit", Tried cleaning no result
Husband suggests that could be coming broken off the brewing unit as it should be activating, He suggests you should get in contact with your local De'Longhi Service Centre (should be info on how to contact in your User Manual, or google De'Longhi for your country).
May 18, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Jan 13, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica "insert brewing unit"
I just figured this out on my machine, I should have taken pictures but i didnt :( this problem seams to pop up whent the elevator that moves the brewing unit up and down gets its starting position mis aligned, since the machine does not have sensors to re adjust the alignment the motor will pull the elevater down even if it cant go further and that seams to cause the nasty noise we were hearing.
1. unplug machine
2. remove the side and back covers
3. remove tray and brewing unit from inside (2 red buttens you press together)
4. remove the bracket that holds the brewing unit (2 hex screws)
5. below the brewing unit bracket is one more screw, it holds the motor unit and elevator on the back of machine, remove this screw.
6. on the back pull out the motor unit with elevator.
7. realign elevator starting position by turning the bottom wheel that is connected to motor via belt, it might feel a bit stuck first as motor has ower tightened the elevator.
The back of the elevator looks like a step ladder with screw going up the middle, for me it worked best to align the bottom of the traveling bracket with the bottom step on the ladder i recomend trying that position and then adjusting if nessesary.
8. reasemble the machine and continue to enjoy exelent coffie
Aug 08, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
3,670 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
