Question about Dell Computers & Internet
Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
Dell Inspiron B120 locked keyboard at intial startup. I can not sign in. The mouse pad works, but not the keyboard. The FN(Function) and ESC( Standby) will put the PC in standby mode.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 127 Answers
Your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking. shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8. advance boot up options will appear. select safe mode with networking
try restoring your comp to a previous time when it was working. if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
Good Luck!!
Posted on Jun 01, 2009
  • smayday Aug 06, 2011
    Is this supposed to work with an Inspirion mini 10 also
    Would this process work on an Inspirion mini 10 also. I have the same situation but F8 isn't doing anything on startup. Maybe an unplugged keyboard?
Touchpad
Just look out for a mouse-pad symbol on any of the function key of your keyboard.
And then press the 'fn' key on your keyboard with that key which has symbol of mouse-pad on it. I guess you will be able to access your mouse pad.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
May 06, 2013 | Dell Inspiron 1300 Notebook
How do i turn off my blue keys on my inspirion keyboard
if the number lock on the keyboard is activated, then press Fn + Numlock to turn it off
Jan 09, 2010 | Dell Inspiron 1501 Notebook
Keyboard is not responding it does sometimes then stop again
Step 1
  1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
  2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
    For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
  5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
  6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
Nov 15, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Dell Inspiron 1501 Touchpad locked up
Check the system setup F2 at start, and ensure the touchpad is enabled, next try an external mouse, see if it works.
If and external mouse works, the touch pad has failed and a new palmrest is needed.
Jul 29, 2009 | Computers & Internet
Key board does not work[only blue marked key is workig]
I have a dell laptop and had this happen to me. It's a simple solution, your "Fn lock" is swithed on. Hold down the Fn button and hit Num lock. Now your other keys should be working rather than the blue keys. Hope it helps
Jul 05, 2009 | Dell Inspiron 1501 Notebook
Keyboard and mouse inoperative
check all at bios, maybe it is not well configured and try to update your USB driver, maybe it is not supported version
May 29, 2009 | Dell Inspiron B120 Notebook
Key pad doe not work
This means the number lock is on - in the upper right hand corner of the keyboard is a series of 4 keys.  Far right is delete, then (from the right) insert, Prnt Scrn, and Num Lk.  Hit the Num Lk key, and the number 9 with the padlock should shut off.  Your keyboard should now work normally.
Any more problems, let me know!
May 26, 2009 | Dell Inspiron XPS Gaming Mouse Pad KU170
Fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
Mar 10, 2009 | Dell Inspiron 1501 Notebook
Frozen keyboard
Solution #1, Go to RUN type in 'msconfig'.
In startup uncheck MotiveSB.
Try to reinstall the keyboard driver. Solution #2
  Sounds like it may also be dirt or some spilled soda.
-- Had the same problem after an OJ spill. --
If you feel comfortable about removing the keyboard, disconnect all the wires and cables, then give the keyboard a thorough washing. Then let it dry overnight.
If that doesn't sound like something you want to attempt, then you will have to take it in to a computer shop.
Oct 29, 2007 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
389 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
