Question about Archos Jukebox AV380 80 GB Digital Media Player
Replace screen on AV380
I have a replacement screen for the Archos AV380. However no instructions how to remove and refit, can you help?
SOURCE: archos av380
how to replace the battery for Archos video AV380
Posted on Feb 12, 2010
0 characters
1 Points
How do you change the battery on an archos 7 320gb
The ARCHOS 7 has a removable battery. You can purchase extra batteries if the battery is incorrectly replaced or short-circuited, this could resultin damage to the product and/or serious injuries to the user. Replace onlywith an original Archos battery.To replace the battery, follow these steps:
Jan 24, 2012 | INOi MP3 & Digital Media Players
Archos 704
Did you try power cycling the unit?
Feb 05, 2008 | Archos 704 WiFi Digital Media Player
I need to replace the Archos 5 Android touch screen. I have already separated the screen from the base. What is holding the screen to the frame? Is it adhesive? How do I release it? What can I use to...
same problem here. My digitizer has cracked. My worry is that I don't really know how I could attach a replacement...have you repaired your archos yet?
Sep 08, 2010 | Archos Internet Media Tablet MP3 Player
Can you advise where I can buy a replacement screen for my Archos 705
You can order the screen for the Archos 705 from this link---
Archos 705 replacement screen
Link 2
Hope this helps...
Aug 28, 2010 | Archos 705 WiFi Digital Media Player
Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Jan 08, 2010 | Archos 504 500870 Digital Media Player
Appreciate the direct "Ask Me".
For most Archos products, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 06, 2008 | Archos Jukebox AV380 80 GB Digital Media...
My LCD screen on my Archos 404 broke i know where i can get a replace ment ( but i don't know how to fit it in to archos. can you help, thank you
1. get a LCD screen from
2. use a bit of card or credit card and slide it between the LCD screen and the front this removes the glue
3. remove four screws on the sides
4. remove the back
5. lift the battary and unplug
6. lift the hard drive
7. remove the two screws in the corners
8. now you can remove the front
9. lift the LCD screen so you can see the cables
10. slide the cable out of its housing
11. to put the new screen in follow numbers 10 to 3
when removing the glue or the front of the archos do not touch the LCD screen as now its not fixed it will brake
Jul 19, 2008 | Archos 404 Digital Media Player
Archos 605 160G Error cod 102
Hi everybody i just got off with archos USA tech support there is no other way but to send it in and they wil replace the HDD with a new one. If the archos is not under warranty repair cost is $ 172.50 i think you can buy another one for that price. Although they give you 90 days warranty for their fix.
Jun 29, 2008 | Archos 605 WiFi Digital Media Player
Broken Touchscreen
Can't help but would sure like to know where you got the screen from desperate for one....Itemcat
Aug 18, 2007 | Archos 704 WiFi Digital Media Player
Archos av380
Aug 15, 2007 | Archos Jukebox AV380 80 GB Digital Media...
Archos Jukebox AV380 80 GB Digital Media Player Logo
32 people viewed this question
Top Archos MP3 & Digital Media Players Experts
 Mike M
Mike M
George Hoggarth
Level 1 Expert
Are you an Archos MP3 and Digital Media Player Expert? Answer questions, earn points and help others
