Question about Refrigerators
I have a logik lfc50s10 fridge freezer It's making a bubbling noise and the fridge isn't cold and the freezer is a bit cold but everything has defrosted what can i do to fix it?
2 Suggested Answers
SOURCE: Beko frost free fridge freezer,
sounds similar to mine. Find the source of the bubbling noise (defrost timer at the bottom), remove the cap and advance the timer with a screwdriver. If you fridge starts working, your defrost timer is faulty.
Posted on Jul 28, 2008
Fridge isn't cold. Freezer is cold but frosting up
Is the fan in your freezer working? Make sure the door switch is pressed in when checking as it cuts the fan out when the door is open. Does it have a manual defrost timer?
May 13, 2013 | Refrigerators
Logik refrigerator lfc50s10 has a blocked drain hole how do i clear it
Logic fridge/freezer
no! I pushed a plastic coated flexible steel wire down the hole and it hit something solid after 2 feet, I pushed it up from the bottom and it hit the same solid. it feels like plastic, I blew down the pipe in the top hole and water blew back. Water is not flowing down.
Mar 01, 2012 | Refrigerators
The freezer works fine; the refrigerator isn't cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 30, 2011 | Refrigerators
The freezer side of this unit quit freezing. Everything is thouging out. Fridge side isn't as cold as it used to be. Both controls have been set on factory recomemded settings since install. I keep...
A popping noise? Could it be the clicking of a relay? There is a relay that activates the compressor that could cause a clicking sound if it doesn't hold. A popping sound could be a bad capacitor but normally isn't a continuous popping sound, unually only one pop.
If the unit is only 4 monthes old it should still be under warranty and you should call it in for repair.
Jun 16, 2011 | Refrigerators
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Clicking Fridge
I used to have a whirlpool fridge, they are the ones who make kenmore too. It used to make a loud thud noise. It was the compressor turning off. sometimes it was loud enough to wake me up at night. It did this for years and I never had any problems with it. when I purchased a larger fridge I sold it to a friend and its still working today. If you can tolerate the noise I wouldn't worry about it unless it starts giving you trouble.
Nov 01, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
