Question about Toshiba 32A43 32" TV
Tv volume turns down by itself
Sometimes set will not even come on if it does volume will turn down on its own
  • 36 Answers
I had that happen to me once and found that one of my remotes was under the sofa cushion, However, I would look at the connections on the pcd that has the volume controls on them, the down switch either has moisture or corrosion behind it, or the switch itself is faulty, if not, remove all dust from inside the set, some may be causing conductivity on the processor, I believe it will be a mechanical type fault rather than electronic...try that...Phil
Posted on May 19, 2009
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
Magnavox ms 3252s431 Bad picture and turns off by itself
Hello, Change horizontal driver buffer transistor's and capacitor's. 7461 7463 transistor's. Caps 2455 2405 near transistor's. Please leave your email address, I will try to find the service manual for you. Best regards, Arpi
Jul 26, 2007 | Philips Magnavox MS3252S 32" TV
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Samsung plasma tv #pl42b430p2d volume turn up &down itself
hi the v+ is dirty or just bad maybe every taster
Nov 26, 2013 | Televison & Video
My emerson tv keeps turning the volume up and down by itself
There is an IC inside the set that is suppose to control the volume and maintain the level it is set to and not let it get to high on commercials or to low in love scenes.this IC has gone bad, common problem in Emerson. IC isn't very expensive, although sometimes it's in with other things on a 64 pin IC. Little tiring desoldering and soldering it back in.
Gillight
Jun 22, 2012 | Emerson Televison & Video
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Hi, I have a samsung le32r74bdx lcd tv and the volume has just gone to 100 and i can't turn it down?
First, start by unplugging set to try to reset. Then make sure that all settings in audio menu are correct. Also look for stuck volume up button on set and on remote. Sometimes buttons get lodged under surrounding frame. Also try to push volume down button on tv and watch for display on tv to see any change. If when you release button volume increases by itself, remove batteries from remote to eliminate it as cause. If nothing you try works expect to replace main pcb. You can probably price it online with model number. Good luck, Russmann.
Jun 09, 2008 | Samsung Televison & Video
Volume Does what It wants
My Yahoo YHT-400 does something similar, only it won't do it right away, it has to start getting hot first, then if I have the volume set at 25 or higher, it will slowly start turning itself up louder until it either maxes out, or I intervene. Either way, it's really annoying, even though I'm only using it as an amplifier for my computer. I just figured it was doing it where it's second-hand and had tons of dust inside caked in and around the fans until I cleaned it out. But when on AUX/TV, one would think the Bit Rate Transfer gauge would remain at 00, but it jumps up and down constantly, whether there's any audio being put through it or not.
Aug 18, 2007 | Yahoo YHT-630 System
Toshiba 32A43 32" TV Logo
392 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
