Question about Epson Stylus C66 Inkjet Printer
Printer won't print
Power light and ink light stay on but printer won't print.
  • 42 Answers
U refill the catrige? if u do this the printer don't work because the catrige has abloody chip that count the ink, and when the ink finish the chip blocks or burns. so try whita brand new catrige.
Posted on Oct 18, 2007
I replaced the black ink and the error light is on and the out of black ink light is still on. Won't print
Try it.......
Remove the print head and soak it for three 5-minute cycles in hot (~170 F) distilled water about 3/4 inch deep with continuous mild agitation. The first soak quickly turn the water black, the second end with the water a dark grey color. The hot distilled water dissolved the dried ink in the small ink passages from the cartridges to the ink ejection part of the print head.
Carefully dry the print head as per instructions, clean the electrical contacts on the printer, and placed the print head and the ink cartridges in the printer.Turn off the printer, then unplugged it for one minute.Then turn it on...and print an alignment sheet...
If you need any technical help on printer then you can reach at
Nov 20, 2012 | Dell 1320c Laser Printer
My printer won't shut off or print, lights keep blinking, computer won't boot if printer is on, must pull the power cord. Does my printer have a short in it?
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
Nov 06, 2011 | HP DeskJet 970cse InkJet Printer
Have not used my Epson R1800 for almost 6 months. When I turn on the power the printer head, with the cartridges, stayed at the very right end, not moving. The paper and ink lights flash and the head just...
Your User's Guide is available here:
After leaving the printer inactive for a extended period you should expect the ink cartridges to be dried up and the print head 'gummed' in place.
You will need to refer to page 82 of the pdf, Cleaning the Printer.
As part of cleaning remove the existing ink cartridges and while the cartridges are removed try and clean the print head of any ink residue. Note that if the red light is on or flashing above an ink cartridge the printer sees it as empty (dried up).
The print head will not move if ink cartridges need replacement; replace ink cartridges according to the red lights, likely all. Press the ink button to see if the printer will begin the charging cycle. If all is well the green power light will stay on and the red ink light will go out.
If you do not get this desired outcome try Cleaning the Print Head, page 73 of the User Guide. Hold down the ink button when the red light is off for 3 seconds. Run a nozzle check pattern; if nozzels are not printing a clean pattern, repeat this process up to 3 or 4 times.
Feb 03, 2011 | Epson Stylus Photo R1800 InkJet Printer
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
C43 stylus does'nt print while red and green lights stay on
If the light are flashing, it mean waste ink full. You must clean waste ink pad, and reset the counter. You can use SSC, find at But,.. you said the light are on. try to resinstall driver. after printer recognised by comp, check status monitor. Green light on is power on, and red on mean chip error/ink out error/cartridge error.
May 29, 2009 | Epson Stylus C43SX InkJet Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Epson Stylus C66 Inkjet Printer Logo
116 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
