Canon ir2018 system error e008 - Office Equipment & Supplies
5 Suggested Answers
  • 990 Answers
SOURCE: error code 007 appears on my canon iR2018
Hello sir; You may go to make a reset procedure as follow; press "additional funtion"(*) key "2" and "8" key in order, then sssw will display, press "OK" key, then select menu item 1 using up/down arrow key, select bit switch 1 using left/right arrow key, then change data from 0 to 1 or from 1 to 0, then press OK, press Stop .
Posted on Sep 16, 2009
randula7
  • 78 Answers
SOURCE: System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Posted on Jan 10, 2010
  • 16 Answers
SOURCE: how to fix my canon IR2018 system error E007
this error is normally related to the hot roller in the machine
Posted on Feb 23, 2010
  • 109 Answers
SOURCE: canon copier iR2018 showing 'system error E007'
your problem in the fixing unit replace the upper fuser roll
Posted on Apr 01, 2010
The canon Copier Brand iR2018 on the screen indicates a System Error E805, when machine is switched on.
Canon iR2018 Error Codes
This weblink states:
Code
E805-0000
Description
Fan failure
The fan is faulty.
Remedy
- Check the fan connector. - Replace the fan. - Replace the DC controller PCB.
Feb 16, 2018 | Canon Office Equipment & Supplies
SYSTEM ERROR E007 ON CANON iR2018
Call to 1-800-243-0019 Canon ir 2018 system error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film.
Apr 15, 2017 | Canon Office Equipment & Supplies
Canon ir2018 error e808 how to clear
To clear the E808 code unplug the machine for about 10 minutes. If the thermistors are bad the code will appear but will not reset until the fixing film assembly is replaced. If you have tried to repair this machine, make sure you have not left the connector unplugged.
Jul 30, 2014 | Canon Office Equipment & Supplies
Canon ir2018 copier error messages E000 and E003
hi that errors indicate there is temperature failure in the fixing unit maybe caused by AC energy fluctuations . . . verify energy supply is correct . try to connect the machine in another Ac outlet. if problem persist maybe the fixing heater is malfunctioning
Jun 14, 2012 | Canon Office Equipment & Supplies
Where do i find the fixing film?of the ir2018 canon printer. what does it look like and how do i replace it? mukopaje@live.com
hi,
please do following
m good with laser printers but when it comes to copiers. ... I have a Canon IR2018 MFD copier. It started giving me the e007 error. I know this has somthing to do with the fixing film. ... Does anyone have a service manual or a technical diagram of a canon ir2018 copier.....that would help alot. ...
www.copytechnet.com/.../canon/41455-canon-ir2018-fixing-film-replacement.html - Cached iR2018 fuser replacement... Repost for mnamono‎ - 7 posts - 27 Oct 2010
IR 2018‎ - 9 posts - 20 Apr 2010
More results from copytechnet.com »
May 30, 2011 | Office Equipment & Supplies
Instructions for ir2018 canon copier how to use
Here is the link for the manual http://files.canon-europe.com/files/soft37766/manual/m_iR2022_iR2018_BGR.ZIP
Feb 28, 2011 | Computers & Internet
Cannon ir2018 system error E007
E007 is fixing film problem. Worn-out fixing film.
Sep 28, 2010 | Canon iR 2016i Black and White Copier
E805 is Fan failure
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
E008 error code on canon
Brother DCP-8065DN Laser Printer no paper error please any solution for that.......!
Oct 21, 2008 | Office Equipment & Supplies
Support for Canon IR2018
hi this is fan failer error.. pls check ur machine optics fan or fuser fan. any one geting damaged or not connected properly.. pls check this..
Aug 04, 2008 | Office Equipment & Supplies
69 people viewed this question
k24674
jasbo
jasbo
