Question about Refrigerators
Iberna fridge freezer manual
Just turned the fridge freezer back on . Do I press the Booster button to help it get to the correct temperature
watugot
  • 290 Answers
SOURCE: Freezer keeps beeping and switching off
Next time this happens unplug it for about 10 minutes. When you plug it back up you should be able to turn it back on normally. This resets the board, much like restarting your computer. If the problem happens again, you will probably have to replace the board. You also want to make sure you have a good ground on the circuit and a steady power supply without too much fluctuation. Hope this helps.
Posted on Oct 07, 2007
  • 14 Answers
SOURCE: Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Posted on Jan 17, 2008
kweaver1
  • 3 Answers
SOURCE: AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Posted on Jan 20, 2008
  • 958 Answers
SOURCE: Pressed a button, now fridge won't work
you have pressed the defrost button that is why the compressor stops and would not come back on. there could be a temperature sensor on the thermostat or a timer where in it would only reset back after the temperature of the fridge warms up. try to remove all the food and let is sit for a while, plugged and watch if the compressor would kick in after about two hours or untill the fridge warms up. if the button is stuck, you may have to spray lubricant in the thermostat or replace the thermostat .
Posted on Feb 21, 2008
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
Where is the reset button on samsung freezer
You have to press power freeze & fridge buttons at the same time to reset
Sep 08, 2017 | Samsung Refrigerators
Can't find the manual for my Iberna Upright Showcase. Model: GD350 and No. 201205. The temperature is much higher than it is meant to be and I can't adjust it.
a UK brand
probably discontinued
cant find a user manual on line for it
my guess is you need to replace the thermostat or the control pad
contact this company
http://www.partmaster.co.uk/iberna/fridge-freezer/catalogue.pl?shop=iberna&path=499408
Apr 30, 2016 | Freezers
Hiw di I set the temp to the correct temp
turn freezer to mid point and try fridge on 3.5 as a starting point.
Keep the refrigerator temperature at or below 40° F (4° C). Thefreezer temperature should be 0° F (-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these temperatures and are generally inexpensive.
press the helpful button and check link below
Fridge temperature guide Kitchen
Jan 29, 2016 | Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Hi, i need to set temperature for my 6th sense american fridge/freezer.. panel shows -24 deg for freezer and 5 deg for fridge..can you help me pls ?
There are buttons for fridge temperature and freezer temperature on the control panel. Just press the relevant button repeatedly until the temperature you want is displayed. http://docs.whirlpool.eu/_doc/501931501055GB.pdf
Jul 15, 2014 | Refrigerators
I have a Kelvinator Fridge P120 Product Code: 10325 and we have no manual for the defrost or temperature dial settings can you help me with a pdf Manual?
Hi Aaron, Apparently this is a Fisher & Paykel fridge made by Kelvinator.
F&P has a support page for manuals, etc., here. I found a fridge / freezer user manual, here. F&P maintains that this manual is applicable to all of their fridge / freezers, so don't be put off by all the model numbers covered (the P120 model is specifically listed however).
If this is not the correct product, please let me know & I'll see if I can find the one for your appliance. I hope this helps and good luck!
Mar 05, 2012 | Refrigerators
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Feb 21, 2008 | Danby DCR34 Compact Refrigerator
Open Questions:
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
