Question about Denon DM38S Audio Shelf System
My Denon DM39 that I purchaed yesterday keeps powering off and then a red light flashes. Coudl it be related to my solar power?
I purchase a new microsystem yesterday - yesterday it shut down when using during the day, but when night came it was fine. Today is the saem story, instantly shuts down. Could this be related to the fact I have solar power and it is causing problems?
  • 29 Answers
Sounds like you system is set up to only provide output current when not charging via the array... its common... shut off or disconnect panels and your problem is solved but the batteries won't be receiving any charge obviously... this set up is used when the systemhas nothing to limit or control the current produced from the arrays/panels from going directly to the attached output devices. This is typical in small pv systems.
Posted on Dec 30, 2013
I have a old denon avr-1804. try to switch on power but can not. just appear a main power red light flashed rapidlly. please tell me why?
Greetings
the red flashing LED is that the Device is in protection mode.
the internal power supply . +15 volts and -15 volts are defected you need to be replace it ... Regulators 7915 and 7815 .... these you should change , might also need to check capacitors .
these are common defects for Denon . AVR units.
Good Luck
Hope this helps
May 26, 2016 | Denon Audio Players & Recorders
Receiver will not operate. when powered on red light flashes, menu displays, than thee is a loud click and the red light keeps flashing. tried the reset and it still does not work.
This sounds like the unit is going in to protect mode. See the link below for further information. Specifically to your unit, we need to know the model number. Also, try disconnecting the speaker cables completely and try again. Update this with how the unit reacts. If the unit powers up fine, then there is a problem with either the wiring to the speakers or the speakers themselves.
Please keep us posted.
Thanks,
Dan
Jun 17, 2011 | Denon Audio Players & Recorders
The green light flashes when power is turned on and then flashes red and turns off. Can this be reset ?
what do i do when my DENON AVR-1506 turns on then flashes red and turns off?
Mar 08, 2011 | Denon AVR-1506 Receiver
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
Denon AVR-2309ci receiver keeps losing power after a few seconds
This is a defective unit. bring it back to best buy and have them replace it.
Jan 02, 2009 | Denon Audio Players & Recorders
Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Dec 14, 2008 | Denon AVR-1908
Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Mar 27, 2008 | Denon DRA-395 Receiver
No power,red power lights keeps flashing.
I had the same problem with the 47" version. I called the Sears technician who tried for more than an hour to fix the problem, even calling Panasonic. Final solution: a board repair for $550. Now I have a plasma and a big desk.
Dec 02, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Open Questions:
See all Denon DM38S Audio Shelf System Questions
Denon DM38S Audio Shelf System Logo
171 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
