Question about Fujitsu fi-4120C Path-Through Scanner
Sa01020e fujitsu error - Fujitsu fi-4120C Path-Through Scanner
How to fix FUJITSU fi 5900C e18 error code Fujitsu fi-5900C Pass-Through Scanner
you need the detail code to e18 to determine the exact error.
First generate the error code again , then hold down the document thickness keys together.
The display should change to a two digit numeric .
You need this code.
Jun 15, 2015 | Fujitsu fi-5900C Pass-Through Scanner
What is the meaning of timer flashing twice in the indoor unit of fujitsu heatpump astb24ldc?
Need to check that models error codes but for most Fujitsu A/C's, that means a "serial signal reverse error at start up" which means your outdoor controller board is stuffed. Try turning the main power switch off for 5 minutes and then back on. If the error persists, you will need a new controller.
May 06, 2015 | Fujitsu Heating & Cooling
Fujitsu 6130 background switching mechanism error
Hi how do you fix Fujitsu 6130 F4 error? Thanks
Mar 20, 2012 | Fujitsu fi-6130 Flatbed Scanner
I have a fujitsu AOTR30LCT, when turned on the green timer light and the red power light blink 3 times. Only the fan works and does not cool.
Error c0de-3.Return air thermistor short circuit.
This sensor when it's defective, will not command for compressor for working.
Replace it.(Room air sensor). Helpful?
Jan 24, 2011 | Fujitsu Heating & Cooling
How do I run a Fujitsu PC headless?
while booting press F2 to enter to bios setup.
in the main tab go to Boot Features.
the first point in Boot Features is POET Errors will be "Halt On All Errors" then you have to change it to "No halt On Any Errors"
May 13, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
Fujitsu error message
From service manual -
Error message condition one = fan protector operated.
Check:-
Fan,
Main Power pcb,
Main digital pcb.
Feb 21, 2009 | Fujitsu (pds42trs) Monitor
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu fi-4120C Path-Through Scanner Logo
120 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
