Question about Kyocera Mita Ecosys FS-C5100DN -23 PPM Duplex Network Color Laser Printer, 1102HL2US0, FSC-5100DN, FSC5050-DN, FSC5100DN
Error on Kyocera FS-C5100DN call service 2830:0019507
Soulvisitor
  • 1113 Answers
SOURCE: Kyocera Error
Signifies comunication error between mainboard and engine.
Only hope would be check and reinstall printers firmware via flash card in side socket.
Check connections on the boards.
Replace main board.
Error is stated as for F040: the .0183044 is just page count.. no match for just 040 in service manual.
Cheers
Posted on Jan 03, 2008
Benimur
  • 6966 Answers
SOURCE: Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 12, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Posted on Feb 25, 2009
Comp-U-Doc
  • 148 Answers
SOURCE: the 3rd light on my Kyocera FS-1020d is flashing red, no printing
The flashing is a code. Depending on if it is flashing fast, slow or so on...
Turn to page 32 of this manual for more information.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
Posted on May 15, 2010
  • 241 Answers
SOURCE: Kyocera FS-3900DN Ecosys Call Service 2200:0100998
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
Posted on Jun 09, 2010
Kyocera FS-C5100DN shows Error message "close front cover" what to do??
it is in the left front of the machine the cover you open to change toner should have a actuator that pushes the switch that could be broken off or 1 of your toner cartidges may not be set correctly remove all of them and close the cover if it says install toners do that 1 at a time see if it keeps saying install cartriges until all are installed or you see close cover message after 1 is installed that would be the 1 not installed correctly causing your close cover message
Mar 29, 2017 | Kyocera FS-C5100DN Color Laser Printer 23...
Why is the kyocera fs-c5100dn print smudging
If the final product is smudging after it prints out the fuser unit is not working and the toner is not fused to the paper. Also the paper should be warm when it prints out.
If it is during the printing you may have loose toner in the printer that is contaminating the print process.
Aug 29, 2014 | Kyocera FS-C5100DN Color Laser Printer 23...
Kyocera service codes
Magenta developer unit non- install-
ing error
• The toner sensor 1 inside the magenta
developer unit did not output the den-
sity detection signal, judged the
engine controller PWB (KP-1054) the
magenta developer unit is not
installed.
You may want to leave that to a certified tech!
Aug 29, 2014 | Kyocera Office Equipment & Supplies
Error on display call service 7402:0005942
The machine is not detecting the cyan developer unit . I would first try reseating the unit or replacing it.
Jan 29, 2014 | Kyocera FS-C5100DN Color Laser Printer 23...
ERROR CODE F186 FOR KYOCERA FS-C5100DN
Guten Tag,
Kyocera FS-C5100 error code 186
was sagt der fehler aus
Aug 06, 2013 | Kyocera FS-C5100DN Color Laser Printer 23...
Kyocera error f186
Upgrade firmware to the most recent version.
Kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Feb 02, 2011 | Kyocera FS-1016 Printer
We have a kyocera fs-c5100dn. When printing credit card reciepts it takes around 1.5 minutes. Is there some way to speed this up?
The printer probably is going into "power-saving" mode after several minutes of non-usage. Then, it must "warm-up" for 90 seconds, in order to print the page. Reconfigure the printer to stay "active" for a longer time, like 30 minutes, before entering "power-save" mode.
Sep 01, 2010 | Kyocera FS-3900DN Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita Ecosys FS-C5100DN -23 PPM Duplex Network Color Laser Printer, 1102HL2US0, FSC-5100DN, FSC5050-DN, FSC5100DN Logo
485 people viewed this question
Top Kyocera Mita Computers & Internet Experts
gbob59
Computer Links
Phillip Hicks
Phillip Hicks
Are you a Kyocera Mita Computer and Internet Expert? Answer questions, earn points and help others
