Driving test questions - Computers & Internet
Dell error code 2000 0146
That Dell error code indicates a hard drive issue. The link below has some information about running Dell hard drive diagnostics which don't require being able to boot to Windows. (There are other ways to test the hard drive by booting with a Repair CD or other tools, but the Dell test should be sufficient.)
Jan 16, 2014 | Computers & Internet
I need this drive to work my pc in internet i need this drive you can helpme?
You need to make your question clearer. If your having problems with your optical drive then ensure its drivers are installed by going into control panel>system>hardware>device manager and ensure there are no yellow triangles next to it.
else download and run SANDRA Lite and run the diagnostics tests to test the drive
Sep 17, 2010 | Computers & Internet
Can't get Dell Desktop to recognize cd/dvd on D: drive
With any computer this is a question that must be answered by those that provide the driver software. Like the number above (Dimension 3100) you should begin your search here=> Dimension 3100 Drivers that is if you have not altered the driver by putting a different player in the slot. What you need to do is test the drive using the Dell diagnostics. The procedure can be found in the CD/DVD FAQ. Run the "read test". You'll need to insert various disc types during the test. This came from Dell Forums. Click Here=> Dell Forums/Osprey and Here=> Search Results for "Dimension 3100 DVD Driver"
Hope this helps, Thanks, Sea Breeze
Jul 14, 2010 | Dell Dimension 3100 PC Desktop
Washer fills, agitates and drains but will not spin (any speed or cycle).
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the agitator
  • Inspect the pump coupling
  • Test the water level switch
These are the common problems of a washer that will not spin. In my opinion I would say check the transmission. Any more questions feel free to ask.
Dec 02, 2009 | Frigidaire FWTBB30DS Front Load Washer
I just bought a used 1998 Jimmy. 4 wheel drive wont pop out when I push the 2wheel drive button what do I do?
replace transfer case module it bolt to the side of transfer case above dfront driveshaft
Aug 19, 2009 | 1998 GMC Jimmy
Emission /02 sensor diagnostic system not ready for testing
Hello, Sometimes you have to drive 20, 30 minutes or more before the computer loses the code and resets unless you still have a problem
I hope this was helpful.
CYA, Gator241
Feb 07, 2009 | 1996 Volkswagen Jetta
Car pulls hard to left all of a sudden in test drive Le mans
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question.
Feb 03, 2009 | test Drive Le Mans for Dreamcast
I have a maxtor 6L080M0 hard drive that has crashed The return code is 7 Is there any way to fix this problem.
If the following determines you have hard drive failure then you may have to purchase a new HD. Follow what is recommended from the manufacturer below. READ EVERYTHING.
According to Seagate the makers of Maxtor, you have a DiamondMax 10 (6L080M0). See below or click here
My internal hard drive may be defective, how can I test it?
Question
My internal hard disk drive may be defective, how can I test it?
How can I determine if the problem is with my system or with the hard drive?
It is necessary to run the SeaTools, SeaTools Enterprise, or SCSIMax diagnostic before contacting Technical Support 1.800.SEAGATE (1.800.732.4283) on an internal drive that may be defective.
Answer
For Seagate or Maxtor (or Quantum) ATA drives:
If this is a Seagate or Maxtor (or Quantum) ATA or SATA drive, please download the SeaTools for DOS diagnostic to test it. If the drive is failing, the tests in SeaTools for DOS will indicate as such.
If the BIOS does not recognize the drive or the drive does not spin please reference Answer ID: 48
The operating system will not recognize a drive that is not formatted and partitioned. If you need help with formatting:
  • Windows 9x and ME reference Answer ID: 3076
  • Windows 2000 Answer ID: 880
  • Windows XP Answer ID: 3361
  • Windows Vista Answer ID: 3844
  • Macintosh Answer ID: 492
    For Seagate SCSI drives:
    Please download the SeaTools Enterprise Edition diagnostic.
    For Maxtor (or Quantum) SCSI drives:
    Please download the SCSIMax diagnostic.
    SeaTools, SeaTools Enterprise, and SCSIMax will test your S.M.A.R.T-compliant ATA, SATA, or SCSI disk drive for media defects, perform a read test, physical head test and ensure the hard drive is functioning correctly.
    If all the tests pass (no trouble found), the problem remains elsewhere in your system. Reconfirm all settings for hard drive jumpers, cables, and ATA, SATA, or SCSI controllers, and disk operating system. Consult your host controller documentation or system manufacturer for assistance with SCSI termination or ATA / SATA controller capabilities.
  • Jul 04, 2008 | Computers & Internet
    Hard drive Self Test
    If I may ask a dumb question, was the new drive formatted prior to running the test? A unformatted drive will fail.
    Sep 12, 2007 | HP Compaq Presario V2555US Notebook
    Computers & Internet Logo
    David Payne
    David Payne
