Question about White Sewing 2037 Mechanical Sewing Machine
Ce-200 My ce-200 continues to have problems with the bobbin. The bobbin case jumps out and becomes "unhinged"..please help, i've tried to adjust the metal piece that keeps it in place, but it continues to do it over and over, breaking needles, jamming...so frustrating
  • 29 Answers
Is the Bobbin the right size for the machine? That may keep the bobbin case from latching properly, causing this phenomenon. Shuttle latched in properly? Machine cleaned and oiled per the manual? Make sure bobbin is wound straight and correctly... Post with results or follow up questions
Posted on Dec 30, 2013
SOURCE: Bobbin movement
I got my machine back from the repairman for the same issue. Check the two levers on the left and the right of the black bobbin casing. Somehow, when I sew thick items, the black casing turns and becomes out of alignment. If you get the two silver levers into their slots, the needle should go through as it did before.
Posted on Jul 05, 2008
  • 1116 Answers
SOURCE: I have a WHITE 3300 EMBROIDERY MACHINE and the
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Posted on Mar 18, 2010
SOURCE: My white sewing machine needle keeps breaking.
take it to a sewing machine repair shop, so the needle bar can be checked, & also the timing
Posted on Jul 29, 2010
SOURCE: The needle thread keeps getting
check to see if the needle is bent
Posted on Jul 30, 2010
  • 1788 Answers
SOURCE: I gave taken out the
Take a look at your manual, and on page 25 there is a pretty good picture of the bobbin case assembly, look at with a magnifying glass and it helps. If, you cannot find your manual, go to www.singerco.com and under customer support, click instruction manuals, enter 1418, now download your manual for free. Then save it to your computer, and you can enlarge the diagrams for easier viewing. It is a good idea to download it and save anyway, because then you cannot misplace it. Good luck
Posted on Dec 30, 2010
The bobbin case moves up and out of position then the machine goes into safety mode. Any advice please.
1. Make sure you are using 15J bobbins. Type 15 WILL NOT WORK. They are slightly different in shape and will deform your bobbin case, making it ump out of position.
2. Take off the presser plate and clean the machine, paying close attention to the area around and between the feed dogs, and under the bobbin case.
3. Get a new needle. The slightest bend to the needle shaft will cause problems.
If you've had this problem for a while, you'll need to take your machine in to be serviced.
Oct 13, 2011 | Singer CE-200 Quantum Futura Computerized...
When I go to fill my bobbin spool, the machine just beeps at me. I've tried everything. Please help!
If you try to wind the bobbin with the embroidery unit on, you need to send a design to the machine before trying to wind the bobbin. If the embroidery unit is off, you should wind the bobbins without any problems
Aug 22, 2011 | Singer CE-200 Quantum Futura Computerized...
The thread and bobbin are nesting up in the bobbin case
Two things I have found that make my singer ce-200 nest. 1st. When I change threads, sometimes I thread it wrong - always nests when I do that. 2nd. When the bobbin runs out of thread it always nests for me, so I have to check the bobbin often. And I remembered a 3rd thing. 3rd. The area for the bobbin & bobbin casing has to be clean, no pieces of threads, and the bobbin casing itself can move, so make sure it's seated correctly.Whenever I get nesting, I take the metal cover off, under the needle, to get in and clean the bobbin area and under the needle good, before I go back to embroidering.
Oct 28, 2009 | Singer CE-200 Quantum Futura Computerized...
The bobbin case turns when i sew
This little "notch" is a stopper and there needs to be a little play so the bobbin case can move approx 2-3mm and allow the thread to pass through. Adjust the spring stopper on the main body just a very little to give it some play and try again....if this was adjusted at dervice, it is not good !
Sep 04, 2009 | Singer CE-200 Quantum Futura Computerized...
Tension not correct
Just set the tension on the bobbin casing but very little at a time, to much and you will never get it wright again. Then also try the tension at the top after adjusting the bobbin casings tension.
Mar 01, 2009 | Singer CE-200 Quantum Futura Computerized...
Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Feb 22, 2009 | Singer CE-200 Quantum Futura Computerized...
A brand new Singer Quantum Futura CE 200 Sewing/Embroidery machine, have not been able to embroider or sew a single stich, all I have been able to do is wind the bobbin. When I'm going to start...
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Dec 08, 2008 | Singer CE-200 Quantum Futura Computerized...
BOBBIN SLIPPING AND STOP EMBROIDERY
First,call the technician and see if he will honor a warranty on his repair work. Next, sew on the machine until it messes up again. Do NOT take all the stuff loose. Take the machine, the garment, the thread,everything just as it is to the technician. Don't even lift the presser foot. He will probably find the problem.
Usually, on a problem such as this, it is the wrong bobbin, the bobbin inserted the wrong way, the tension not working , not threaded correctly, a rough spot on the bobbin case or the bobbin case is not properly positioned.Some times the thread jumps out of the thread take up lever.
sewman7
Aug 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Bobbin case
If your machine is older than 18 months, it needs a free upgrade from your dealer. The plastic see through needle plate needs to be replaced by a newer version that will keep the bobbin down. Further more a bobbin case position finger needs to be installed.
Nov 06, 2007 | Singer CE-200 Quantum Futura Computerized...
Tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Jan 16, 2007 | Singer CE-200 Quantum Futura Computerized...
White Sewing 2037 Mechanical Sewing Machine Logo
53 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
