Question about Drills
Bosch drill charger
The green light on my bosch charger keeps flashing
  • 25 Answers
SOURCE: how long do I charge my 18 v PSR bosch cordless
about 180 mins or an hour and a half. if the light does not change, just make sure you put it properly on the charger base and time it for charging. Disconnect it after you are done. Usually, the light on the charger is just an indication that it is powered on.
Posted on Jul 28, 2009
harlan301
  • 205 Answers
SOURCE: Have a Fire Storm place battery in charger green
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
Posted on Oct 16, 2009
  • 832 Answers
SOURCE: wagner cordless drill ,the charger is not charging
If the charger is no longer working, then, take another
charger to charge the battery of your Wagner cordless
drill. If it charges, then, you have to replace your charger. It is already defective.
Posted on Nov 27, 2009
comax
  • 154 Answers
SOURCE: Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Posted on Jan 09, 2010
rowdy45176
  • 2176 Answers
SOURCE: where can I obtain a circuit board for a bosch
most tool manufacturers don't offer the circuit boards as a separate saleable part. I can't find anything at the Bosch website.
Posted on Jan 23, 2010
Bosch charger not charging
Its sounds simple but always worth a try, clean all the contacts on the charger, one will read the condition of the battery, If this is dirty, it may not be giving a strong enough signal to the charger and as such it will interpret the battery as faulty.
Dec 06, 2013 | Drills
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
My dc18ra makita battery charger flashes red and green lights no matter how many bateries i try
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
Mar 17, 2012 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I've got a Bosch ps30 drill that uses bat411
Directions say green light indicates that the battery is fast charging only,it does not indicate at exact point of full charge. I let my batteries charge for 12 hours for the first time charging,found out myself the same way. Try that and you will notice the difference.
Jul 15, 2011 | Bosch PS30-2A 12-Volt Max 3/8-Inch Drill...
Yellow and green light are on but wont charge battery?
If both lights are on and both are flashing the charger is reading the battery as defective and the charger won't charge the battery. If the Red light (yellow if plastic is faded) is on and the green is flashing the charger is trying to charge the battery. If the battery won't charge replace it.
Dec 21, 2010 | Ryobi Multi-Volt Battery Charger
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
Red and green light flashes alternatingly with only one of my batterys of my makita 18v li-ion fast charger
unplug charger to let it reset. plug back in and then try again, if it still flashes red/green that would indicate a battery failure. check for warranty replacement.
Aug 26, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
18v Litheon drill charger won't charge battery. Green light stays solid even though battery is dead.
It could be the battery or the charger. Best thing to do is find a Bosch service center and have them test them. The litheon stuff is fairly new, there is a good chance it will be on warranty.
Oct 17, 2009 | Bosch Drills
How long do I charge my 18 v PSR bosch cordless drill for as it only has a green light on it and it stays on when I put the drill onto the charger
Jul 28, 2009 | Bosch 33618 1/2" 18v Cordless Drill Tool...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
