Question about Vizio E320-Ao 32 Class Led Hdtv - 720P, 1366 X 768, 60Hz, 200000"
Do you have to have a HD cable to hook up a PS3?
Vizio E320-Ao 32
  • Vizio Master
  • 670 Answers
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Posted on Dec 30, 2013
4 Suggested Answers
  • 14 Answers
SOURCE: connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Posted on Apr 05, 2009
maatmartin7
  • 1208 Answers
SOURCE: CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Posted on Aug 12, 2009
techman007
  • 1112 Answers
SOURCE: i bought a hdmi cord so my son can play ps3 we
Hi:
Check the video connector on the PS3 for a switch to switch from composit video to HD video.
Posted on Dec 26, 2009
My vizeo e320-ao has sound but no picture. is it the backlight
T'Con board fault. Check and replace it if you can. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 10, 2017 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Hi I have acer laptop, I have a cable one end is hdmi and the other side rgb, is there a down load driver so it will work. thank you
If you're trying to display output from the laptop to the Vizio you'd be better off using an HDMI to HDMI cable. The VGA port on the Vizio E320 only supports 640x480 resolution; you have to set your display output accordingly, usually in control panel. Using HDMI you're able to keep the signal HD, @720p. The E320 also supports 1080i, but you're not going to see all 1080 lines. If for some reason you're trying to go from the Vizio to the laptop it just doesn't work that way.
Jun 24, 2014 | Vizio E320VP 32" LCD TV
Vizio E320-A0 ... no signal
It would appear your signal board was damaged so it will require replacement. . If you purchased s extended warranty on the set it may be covered under the accident provision. If not you can go to Vizios site with the model no and locate the replacement board . If your capable you can order it and change it your self or contact a local servicer to assist or replace the set which may be more economical
Mar 06, 2014 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Can't download manual
http://store.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
Check to make sure you have Adobe Acrobat X Reader or some other PDF reader installed before you attempt download and read this file.
Oct 16, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
I bought a hdmi cord so my son can play ps3 we
Hi:
Dec 26, 2009 | Vizio VW32L 32 in. LCD HDTV
I have a LG HD TV and when i connect a HD component to it, the tv then clicks of after 5 minutes and there is loss of signal from the component eg HD box playstation 3 ect,
there is a short some where or something isnt hooked up right, make sure you go to the main menu of the t.v and sync the cables to the HD and then to your ps3.
Oct 29, 2009 | Vizio L32 32 in. LCD HDTV
Connect home theatre to ps3 to 32" lcd tv
if your tv and home theatre system as all hdmi or component hook ups then follow these steps but only use all one or the other cables.
1. hook the cable from the ps3 to the home theatre "imput slot" (you choose which one you want to use)
2. hook a cable to the output slot on the home theatre system to your imput slot on your tv.
3. turn on all three systems, put your home theatre system on the correct function (which ever slots you decided to put the cables in to the input slots) then turn your tv to the correct AV channel
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Connect home theatre to 32" lcd to ps3
Vizio E320-Ao 32 Class Led Hdtv - 720P, 1366 X 768, 60Hz, 200000" Logo
111 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
