Question about Sony BRAVIA KDL50EX645 50 Inch 1080p Internet TV LED LCD HDTV
Sony bravia 50" red light blinks 6 times.
My tv won't turn on. only red light blinks 6 times.
    Problem Solver:
  • 5 Answers
Slap it.. If that doesn't work at least you'll feel better..
Posted on Mar 12, 2015
    Problem Solver:
  • 15 Answers
The only way to solve this problem is to replace the power supply board. It contains the LED driver circuit which fails early due to a design mistake. Midway Module repairs and updates this module so it does not fail again for this reason. You can find their repair service on eBay. Sony no longer supplies these modules, since they were produced by a sub contractor in Taiwan.
Posted on Mar 06, 2015
  • 468 Answers
One thing you can try is to remove all cords attached to the tv including the power cord. wait a few minutes( maybe say a short prayer) then plug the power cord back in and try turning on the tv if it powers up. it maybe a short in one of the units that were plugged into the tv. If it still does not work it maybe a circuit board problem. Sony Bravias have been plagued with a lot of circuit board issues. type in Bravia problems on any search engine and you will see what I mean. You may be able to get it repaired but you best course of action is to buy a different tv. a Vizio or Samsung or anything but a Sony
Posted on Dec 30, 2013
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
mistersony
  • 320 Answers
SOURCE: Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Posted on Oct 18, 2008
  • 1039 Answers
SOURCE: 13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Posted on Apr 26, 2009
  • 197 Answers
SOURCE: Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
Posted on Jul 02, 2009
  • 194 Answers
SOURCE: My Sony Bravia Kdl40v300 will not turn on When I
sorry. Hope you still have a waranty. This is not an uncommon problem with the sony's. 99% chance that the panel went out. Could also be a balance board issue, but usually not. Call Sony for an authorized repair center
Posted on Dec 24, 2009
Sony bravia KDL46-V3000 inch led Tv red light blinks 6 times???
It means you do have a LCD panel back lights problem, in most of the case, a defective back lights inverter could be the cause.
Jun 28, 2017 | Sony Televison & Video
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 19, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
No picture or sound. Red light blinking four times on sony bravia tv. Suspect power supply problem?
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv. As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from www.partstore.com ----------- Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 18, 2010 | Sony Televison & Video
6 red blinking lights
You have a bad thermal fuse.
Oct 23, 2009 | Televison & Video
Sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Sep 11, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA KDL50EX645 50 Inch 1080p Internet TV LED LCD HDTV Logo
665 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
