Question about GE 36 in. Profile JP968 Electric Cooktop
Error F 135 - GE 36 in. Profile JP968 Electric Cooktop
PIC645F17E (Bosch) electric cooktop show error code er22. What does it mean ? How to repair ? Please help me ! Thank you !
The error code you posted is not listed anywhere. There is the error code "Error" for the oven which means oven overheating. If that's true then the problem is a bad oven power relay board.
This part has been discontinued. Bosch probably replaced it with a different part but I was not able to find the correct part number. You can talk to APP CSR and they will help you to locate the correct part.
Sep 05, 2016 | Cooktops
Tip
Fault Codes Kitchen Aid cooktop
F03 One or more eyes permanently pressed. Recommend that the glas be cleaned and all objects removed.<br /> Unplug the unit for one minute the plug back in if the error still remains after returning power then you will need to replace the touch control module.<br /> <br /> F12 Electronic board and touch module communication error.Unplug the unit for a couple of minutes.Restore the power if the error return then you will need to replace the board connection cable between the touch control module and electronic control. if the error remains replac ethe electronic control board. If the error comes back again replace the the touch pad.<br /> <br /> F13 Internal CPU checksum error.Recommend you replace the touch control module.<br /> <br /> F22 Key sensitivity problem.Turn power off to unit for a few minutes,if the error returns after power is restored replace the touch control module<br /> <br /> F36 Temperature probe hardware error.Recommend that you replace the touch control module.
on Jan 02, 2011 | KitchenAid 36 in. KECC568 Electric Cooktop
Displays error 40. Why won't it turn on?
Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
May 05, 2014 | General Electric Ge Profile Pp975bmbb 36...
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
Apr 10, 2014 | Bosch Cooktops
E30ic80iss electrolux error 31
Good Morning D, I am happy to assist you. Error code E31, commonly refers to an internal generator error in the left side cooking zone and that the generator control board needs replacing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, I would recommend connecting with an experienced appliance repair tech to assist further.
Jul 30, 2013 | Electrolux E30IC80ISS Cooktop
Recently i have purchased Prestige induction stove, can you describe what does E3 mean?
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
Jul 16, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
GE 36 in. Profile JP968 Electric Cooktop Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
