Question about Eureka AirSpeed Bagless Zuum
Jusy shut off while using - Eureka AirSpeed Bagless Zuum
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
Your sweeper may have overheated. I don't know what brand you have but I hope you weren't trying to vacuum pine needles from the Christmas tree. Pine needles are sticky and will clog up any vacuum sweeper. Check your sweeper to make sure the tubes (hose & pipes that carry dirt) are clean and clear. I used to service Oreck vacuum sweepers.
Posted on Dec 30, 2013
Vacuum shuts off while in use
There is a thermal reset inside the motor that shuts it off. There may be a clog.somewhere or something restricting the airflow, it could be clogged filters. If there are no clogs or restrictions it is possible the thermal reset is bad in which case you will have to replace the motor.
Jan 26, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover vacuum shuts off after 10 minuts of use.
If there is no clog the filters may need replaced to improve airflow
Jan 21, 2014 | Hoover Vacuums
Was vacuuming ,it jusy quite no power!
I have seen this before--there is a thermal (heat) breaker in most expensive units---
Look carefully at the air filter to see it is not blocked, one here we looked and it seemed ok but it was washable and when put under the tap in the sink the water ran Black for several minutes, follow instructions on the filter or the manual in this case and wash it if it is washable (paper ones have to be replaced) and let it dry completely.
The way I knew it was blocked was with compressed air not moving free thru it .
It must be completely dry before you try to use---no airflow here will over heat the motor and trigger the internal breaker which monitors current and temperatures.
Dec 11, 2012 | Vacuums
Shuts off after a couple minutes of use
Sounds like it is stopped up. The vac gets overheated and the thermal switch does its job. Check suction from the hose and see what you get. If good then check the brush housing for a clog.
Aug 17, 2009 | Dirt Devil M086700 Vision Bagless Upright...
My ball dyson shut off while i was using it. Now
There is a reset button where the beater bar is. push that and it should work.
Jul 27, 2009 | Vacuums
It shut off ,the water got real foamy and it shut off . will it reset. Do I need to reset it.
it should reset, try not using a sol that has a foaming agent in it.
Jul 16, 2009 | Vacuums
Nothing inn the canister after using,suctione working,bottom roller working,no air leaks from hoses.Also when running awhile it shuts off by itself,have to wait awhile to use again
I'm not sure what vacuum you have, but that sounds like a blockage to me. Thermal shut off kicks in, shutting the motor down, to prevent damage from overheating. After waiting like 1 hour it probably comes back on. Make sure hose, filters, bag (if any) is clean. All "airways" of vacuums need to be clear of any blockages, since airflow is what makes vacuums work.
Apr 18, 2009 | Vacuums
Vacuum won't turn on!!
Some of these have a relay or circuit board down by the main motor that may have gone bad. Could have a problem with the circuit board in the hose handle, Could have a problem with the motor. Will jusy have to have opened up and checked. Go to Sears.com, click on parts, put in your complete model number, a parts list and picture will come up, maybe that will help you.
Feb 16, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Eureka AirSpeed Bagless Zuum Logo
393 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
