Question about GE JVM1860 Microwave Oven
Door handle foe ge jvm1340 bw002
Door handle is broken. Need part and replacement instructions
MicrowaveSvc
  • 9098 Answers
SOURCE: how do you replace a broken handle for a GE Spacemaker II microwave?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
On some models, the handle may rotate into and unlocked position then lift out.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemake microwave handle door
Apparently the part number for the black handle is WB15X10020 and the white one is WB15X335.
You can order either and find find helpful exploded view diagrams here.
Enter the part number to order the part, and enter your model number to find the exploded views.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 18, 2008
SOURCE: Need to replace the handle of a ge jvm1340, the
There is a piece of trim on the inside of the door.
This trim is rectangular, about 1/2" wide, and goes around the outside of the glass. the trim has rounded corners. Take a knife and gently insert at a rounded corner, prying the trim out. Once you can put a finger behind the trim, you'll find it comes off easily, revealing the lower handle screw.
Posted on Aug 11, 2009
  • 10865 Answers
SOURCE: How to replace the door handle on a GE, JVM1490SD 003 microwave?
around the door you will see a plastic cover strip. gently pry it off and under there you will find the screws to open up the door and get to the door handle screws. you dont have to worry about breaching the seal.
Posted on Aug 13, 2009
jsrock516
  • 5911 Answers
SOURCE: Handle broke off my GE Advantium 120 microwave
You are correct. The handle screws can be accessed by simply removing the interior facing of the door, and can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: You can view some excellent exploded view diagrams of your oven at pcappliancerepair.com as reference to see how the parts are assembled.
Posted on Sep 16, 2009
How do I replace jvm1490sd broken handle?
Disconnect, open door, remove screws from rear of door, dismantle door. Here's a diagram showing how it fits together.
01 Control Panel Door Grille Case Parts for GE JVM1490SD003
The part you need is #1801 on diagram
Microwave Door Handle
Color: Black. For white order WB15X10070. For bisque order WB15X10071. For the screws order WB01X10305.
by GE
Part Number AP3184331
May 19, 2014 | Microwave Ovens
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
How do I replace a broken door handle on a GE Microwave JVM1631WB004?
First determine if you can get a replacement handle will you be able to remove the broken handle on your own and install the replacement or will you need the assitance of an experienced repair person.
if you have the tools and know-how to do thihs on your own determine ifyou can get a replacement door handle. Information on contacting GE for parts in Canada can be found here:
http://www.geappliances.ca/parts/index.jsp#3
You could also try their call center: 1.888.261.3055
Make sure you have your complete model number and description of your unit. Was not able to locate information for the model number you provided.
GE Global website can be found here. You may be able to find your model if you check on the website for the country of purchase.
Jan 30, 2011 | GE Microwave Ovens
Need to replace broken door handle. Cannot get to screws inside door to release broken handle and replace with new handle.
Look for a removable insert around the inside window. If not there may be screws along the outside edges to separate the door sections. Eric
Aug 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
Need to replace the handle of a ge jvm1340, the top screw is easy, but the bottom screw seems unaccessible, can you help thanks, JG
Jul 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Broken door handle on GE JVM1490 900 Watts
Go to ;
http://www.appliancepartspros.com/
and enter the model number etc of your unit. Note the diagrams in the left-hand corner of the screen. They also sell parts. Tools will be simple screwdrivers and small wrenches.
Dec 26, 2008 | GE JVM1490 Convection/Microwave Oven
Spacemaker xl microwave oven jvm1630
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You'll need to remove the oven from the wall.
This is safer with two people and the installation instructions will be of great help.
You can download GE owner's manuals and installation instructions here.
Dec 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Instructions for replacing door handle on JVM1350BW02 Microwave
You may have to rotate and pull the handle once the top screw is removed.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Sep 04, 2008 | GE JVM1350BW/WW/AW/SY Microwave Oven
Another broken handle
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
May 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1860 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
