Question about Hisense TL1700 17 in. LCD Television
I try to reset my tv to Queensland setting (because we are in Queensland) but it goes back to Victoria
My Hisense TV is on the Victoria setting and I try to reset it to Queensland (because we live in Queensland) but it jumps back to Victoria. So we do not have the local channals on our tv. Please help
  • 8,016 Answers
Are you using it with an antenna? If so, run a scan again. The tuner will store all channels found in your area (if signal is strong enough). If you are using the TV with cable or some other subscription method check with your distributor.
Posted on Dec 30, 2013
SOURCE: HISENSE TL2020
is it in demo mode
Posted on Dec 29, 2007
  • 13433 Answers
SOURCE: hisense tv
so whats the remote you have there?
Posted on Oct 23, 2008
SOURCE: how to connect sound system to Hisense LCD tv
I phoned the help line at Hisense, they stepped through the set-up - its all good now
Posted on Dec 31, 2009
  • 4090 Answers
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
  • 11800 Answers
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Posted on Jun 04, 2011
Good day. i have a hisense tv that does not stop on the cctv channel i connected to the system. it use to. now it goes past it. there is no way i can stop the search. what do i do?
Try to reset the set electronics to factory defaults. There maybe a reset button on the set itself or if you contact the mfg they can tell you the procedure to do this.
Sep 14, 2017 | Hisense Televison & Video
My hisense 43 4k tv keeps reverting to 480i from 4k when i check the output it says 4k not recognised but then i reset the tv and go back into the picture output menu it lets me put 4k back on my tv
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Dec 27, 2016 | Hisense Televison & Video
I have a 52" hisense tv and when u turn it on it shows the hisense pic then goes black no pic or sound after that can anyone tell me what it is or how to fix it
probable bad connection to video source, cable,satellite try a new video cable, Other then that , you may have to check your TV source setting and select proper feed HDMI 1,HDMI 2, cable, etc.
press the helpful button and give it a try.
Hisense Smart TV unboxing and set up review
Jan 16, 2016 | Televison & Video
Hisense H32V77C password reset
I couldn't find it anywhere in the service manual but you can try calling there support line. default is 0000 if that helps anyPhone: 1-678-318-9074
Fax: 1-678-318-9079
Jul 05, 2012 | Televison & Video
Hisense TL1700 17 in. LCD Television Logo
244 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
