Question about Fisher and Paykel DEGX2 Dryer
Need to reset samsung dryer DV328 - Fisher and Paykel DEGX2 Dryer
Is there a reset on a Samsung dryer model number DV220AEW/XAA
normally if u unplug it for a couple minutes then plug back in , may reset . also try putting it on the on position then open and close the lid slightly 6 times withing 12 seconds, it may reset it
Jun 03, 2014 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Dryer not heating
This problem could be one of many components , heater, t hermostat, thermal fuse, control board, wiring you would need to be noledgable about volt ohm meter to diagnose this problem . but try this turn breaker at panel off and back on this will reset the computer
Mar 24, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
Samsung front load electric dryer not getting hot
There is a thermal sensor type breaker leading to the heating element. They are usually round, about quarter size, with a spade connector on each end. They can be checked by a OHM meter to see if they make a connection from one terminal to the other. There may be more than one. If that checks good then you need to check the heating elements for resistance for one end to the other. If there is no resistance then the element is bad.
Jan 23, 2014 | Samsung Dryers
My Samsung dv328 dryer won't heat
There could be a number of reasons for this issue. 1) If there is lint build up in the exhaust it would reduce heating and could cause a thermostat resistor to blow (safety device for Electric and Gas models). 2) There could be a loose connection where the power cord attaches to the dryer.(Electric model) 3) There could be an electrical issue at the receptacle where the dryer is plugged in to .(Electric model) All of which could prevent the heating element from performing properly. Gas models, I would check the pilot light, check for obstructions in and around the burner, and verify all gas valves are opened, etc. I would start with a good cleaning, check the connections at the rear of the dryer and then (with the use of a voltmeter) diagnose the thermostats and resistors.
Oct 28, 2013 | Dryers
Samsung DV218AEW/XAA not heating
If the technician that came out told you he simply reset your heating element, he was not telling you the truth. Heating elements themselves cannot be reset. The element is either good, or burnt out and would need to be replaced. More common on modern dryers is that the thermal fuse on the side of the heater duct will blow out and needs to be replaced. This is usually caused due to poor air flow because of a lint blockage in the outlet duct. I would recommend calling a good, reputiable service company to repair the issue and to check the outlet duct as well. To get to the heater duct assembly, the top cover, control panel and front panel (including the door) must be removed.
Mar 25, 2013 | Samsung DV218AEW Electric Dryer
I moved to Europe with my Samsung Dryer, however, can make it work as power frequecies here are different 50Hz versus 60hz. How can I change the Power Source Frequency on a Samsung dryer. I am sure that it...
I have the same problem and i was thinking of changing the board 50-60 euros max. Also i have service manual with steps to put the machine in service mode but never found out how to reset power frequency sensors. If you need service manual dbenz@abv.bg
Oct 21, 2010 | Samsung DV328AE Electric Dryer
Samsung DV410AGW Dryer My dryer which is brand new will not start. It appears to have an hour glass on the control panel which i have not seen before. dryer will not start even after i unplugged it...
Sorry to take so long. I have been talking to Samsung support. the hour glass indicates that the dryer is in a cycle, but as it wont start and you've tried unplugging it, it seems there is a fault. Your dryer is new, so you need to contact Samsung for a service visit:
http://www.samsung.com/us/support/service/request
Before doing this, try unplugging the dryer again and this time leave the power off for a few hours - assuming you haven't done this already. It might reset if you do this.
I've pasted a transcript of my conversation with Samsung below. I pretended to be the appliance owner as otherwise they would not answer my questions!
Hope this helps!
info: Please wait for a Samsung Agent to respond.
info: All Samsung Agents are currently assisting others. Thanks for your patience. A Samsung Agent will be with you shortly.
info: You are now chatting with 'Darlene'
Darlene: Hi, thanks for reaching out to Samsung tech support. How can I help you today?
Nick: Good evening
Darlene: I see that you are not chatting from USA. Let me know the place of purchase of the unit.
Nick: USA
Darlene: Please let me know the Samsung Unit model number you have. You can find the model number on the label attached to the right side of the Unit.
Nick: DV410AGW
Darlene: Let me know the exact issue you have with the Dryer, so that I can assist you to isolate and troubleshoot the issue.
Nick: Ok - the dryer is displaying the hour glass symbol, but it's not on a drying cycle
Nick: I tried unplugging it but it hasn't reset
Darlene: Let me know if the dryer works fine when you select any cycle.
Nick: it wont start
Nick: Is there some way of resetting the dryer? I think there is a programme stuck in memory
Darlene: Let me know if you are using Dryer in UK.
Nick: no
Nick: I'm working here for 2 days
Darlene: If your dryer is showing an hour glass on the display, it is normal. The hour glass is there to let you know that there is a cycle in progress.
Nick: I know this. I read the FAQ
Nick: But it wont start and the symbol remains even after it's been unplugged
Nick: Can it be reset?
Darlene: Let me know if you have tried to unplug and replug the unit from different wall outlets.
Nick: Cmon, be serious
Darlene: There is no option to reset the Dryer, only way is to unplug and replug the unit from power.
Nick: It's not my outlets
Darlene: I am sorry, a physical diagnostic is necessary to determine the exact defective part on your device.
Nick: I left it unplugged while I am away
Nick: I will try when I get home
Darlene: I recommend you file online service request to schedule service appointment, there you can get the Service Center information, so you can contact them.
Darlene: Would you like me to provide you with the link to fill out an online service Request?
Nick: Yes please
Darlene: Visit the link given below to file an online service request to get the Dryer serviced:
Darlene: http://www.samsung.com/us/support/online/supportOnlineServiceRequest.do
Darlene: Fill the required information to schedule the Service for your Dryer.
Nick: Please answer one more question for me . . .
Darlene: Sure, please go ahead with your question.
Nick: Is the dryer equipped with a memory so in the event of a power failure, it will restart when the power returns?
Darlene: When power fails, Dryer will start from the beginning of the cycle.
Nick: OK, so unplugging it should fully reset it?
Darlene: Yes.
Nick: OK, If that's the case I definitely need a service request
Nick: Thanks for your assistance
Nick: Have a good evening
Darlene: You're welcome. Is there anything else I can assist you with?
Nick: No thanks
Darlene: Thank you for chatting with us. If you have a minute, please click on the blue "X close" button to receive a transcript of your chat and fill out a brief survey to help us serve you better. Have a Good Day!
Nick: Goodnight
Oct 20, 2010 | Samsung DV410AGW Dryer
I have a samsung dryer dv328aer that stopped heating up.
Check the home’s circuit breaker and fuses. Electric dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Select a heat setting other than Air Fluff.
Clean the lint filter and exhaust duct.
Another common cause of a dryer failing to heat is a faulty element (Heating Element). You'll need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Samsung DV328AE Electric Dryer
Fisher and Paykel DEGX2 Dryer Logo
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
