Question about CBTL Coffee Makers & Espresso Machines
Cbtl coffee maker has a solid red light on. will not make coffee
Cbtl coffee maker does not work anymore. It has a solid red light on.
SOURCE: Saeco Italia SUP021 YR - Red light #29 on solid
Comment on oily beans - try not to use them. If you are looking for a stronger flavor coffee, an an extra shot to your drink. Oily beans cake inside the grinder, brew group + components and strains them potentiallu causing malfunctions.
Also dark beans are usually over roasted which makes the makes real coffee flavor lose. Espresso coffee beans should have very little to no oil and be unifrom in color.
Another approach if you are looking for stronger coffee flavor. use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee. Visit http://www.coffeetico.com/did_you_know.htm for some more interesting information.
Posted on Jun 20, 2008
freetek
  • 5568 Answers
SOURCE: stopped working?
All coffee-makers are provided with a thermal fuse located near the heating element and in series with the element itself.
This device is bullet-shaped with one lead connected to the case, the other insulated from it. If there was no protection of this kind, it could lead to a fire if the heating element fails to get turned off when reaching its design temperature and nearly impossible to buy as replacement parts.
These are not user replaceable and both the thermal fuse and the bimetal switch that controls the current for the heating element have become increasingly less reliable as they are made in China and since we have little alternative, we have to either keep track of our warranty or just throw it away when it fails.
The fuses can fail at any time and I have brought back three coffee-makers in a five day period, all with the same failure, before giving up and getting a refund.
Another type of failure, namely of the bimetal switch occurs over time and reveals itself by the ever-longer brew time that is unaffected by dissolving the lime in the system. The heat sensitive metal switch part becomes gradually less responsive causing the machine to just cough instead of pump as when new.  The last one I tossed had reached 40+ minutes per pot.
Posted on Jan 23, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: GE COFFEE MAKER 169123
Here is a link to the GE parts page:
http://www.gehousewares.com/Customer_Assistance.aspx
-Tha Mp3 Doctor
Posted on Mar 09, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
Posted on Mar 21, 2009
rhondam_owen
SOURCE: coffee maker doesnt work
I can't get my coffee to brew. I pushed the on button and even tried to program it! no coffee. Can someone help me please?
Posted on May 15, 2009
My coffee machine won't work.
time to replace if not under warranty still
Sep 08, 2016 | Coffee Makers & Espresso Machines
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
Red light comes on but coffee doesn't brew
If there is a thin water line in your coffee maker, then it can get clogged or could have mineral build up. Keurig coffee maker, you are going to want to descale it every 6 months. Calcium can build up.You need to run a large cup of white vinegar through coffee maker lines. When you run vinegar through there, the coffee will taste nasty, so I would run water in there several times, after the vinegar finishes. Run through until does not taste nasty anymore. Yeah, I do this with my coffee pot 3 times a year. You judge how often you should.
Good luck.
Sep 06, 2012 | Cuisinart DCC-1200 Coffee Maker
Reset clean filter light
I found that unplugging for a minute or two, the light goes off, then I pushed the select button until the red light comes on solid, not blinking and will proceed through the cleaning process ( have the cleaning solution or vinegar in the reservoir). The red light will then go off once the cleaning process is over. Hope this helps.
May 08, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Coffe does not stay hot in carafe
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Mar 19, 2008 | Krups ProAroma 453-71 Coffee Maker
Coffee Makers & Espresso Machines Logo
65 people viewed this question
Top CBTL Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a CBTL Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
