Question about Cell Phones
Blinking problem alinco dr140
No transmit no receive
Alinco dj 195
flashing display means that the pll is out of lock, the radio needs to be serviced
Aug 21, 2014 | Radio Communications
Scratchy rec audio
Could be several things, controls need cleaning, use contact cleaner, could be bad speaker, replace, caps on audio section need replacement, service with correct components, could be bad audio amp, replace with correct replacement. Not enough info to say for sure
Mar 13, 2014 | Alinco Radio Communications
Scrathy rec audio
older batteries or not fully charged batteries can cause distorted RX. if your batteries are more than 2 yrs old they should be replaced. also dirt or moisture in the radio speaker, or trying to talk beyond their Range can also cause distorted RX. you use most of your power when you transmit.
MY ALINCO DUAL BAND 2 METER/70CM HAM RADIO DISPLAY STARTS TO BLINK SHORTLY AFTER POWER UP
Hi Leslie,
This may lead to the info you need to resolve the issue.
Join yahoo group Specific to your radio Make/Model, Be as detailed as you can when giving them your queries. They have a wealth of info and you can download manuals, schematics and other goodies for your radio, if available and all this is free.
I hope you do resolve the blinking issue with your Alinco.
Cheers,
Peter
Mar 17, 2013 | Alinco Radio Communications
Hi guys, my alinco dj596 cannot receive but can transmite,how i solve this problem?
Which one is it? ALINCO or MOTOROLA?
DJ 596 indicates ALINCO, and they are two totally different radio makes. Alinco is a great Japanese brand, any way to get to your query....
I'm only guessing due to lack of info from you, that you've tried the volume controls on your radio?
If so, has this problem only recently occurred or has it been present since you got the set?
This is info we need to be able to assist you.
Cheers,
Peter
Jun 29, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
Need Manual for DR140
hi friend,
go to website
www.eserviceinfo.com › ... › Radio stations › HAM radio-stations -
u can download the user manual from there
hope this helps u
please rate me..............
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Alinco Radio Communications
Alinco DR-635. On two meters, there is no received audio.
I think your 2M section has a dead FET in the receiver front end. The FET transistors are bad about being destroyed by ESD, as they are not gate protected. This is a repair shop job, unless you are very good with repairing surface mount technology. The 635 is a good rig, well worth the repair costs. Consider using a factory repair shop, to get the job done right. There is an Alinco group on Yahoo Groups, join them and ask where to send your radio for repair. They will know who is reliable enough to trust your treasured radio to for repair.
Good Luck,
Longshorts.
Jul 06, 2009 | Radio Communications
Circuit diagram for alinco vhf base dr112t/e
go to n go to and join yahoo alinco group
Mar 08, 2008 | Computers & Internet
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
