Question about Maxon Music
Maxon B14 807.750 mhx bdy pack. need a new crystal and cannot read what it is!
The crystal in the B14 body pak has a broken leg and am unable to read its value. it is 807.750 mhz.
How do I factory reset my Casio CTK-2400 Keyboard?
You manual is here http://support.casio.com/storage/en/manual/pdf/EN/008/Web_CTK2400-ES-1A_EN.pdf
Interestingly...check out page EN-34...about the section on local control...Follow the directions to turn your sound back up... Good luck
Feb 23, 2015 | Casio Music
Marshall mg102fx cuts out
I've seen a bunch of Marshall Combos and a very common failure comes from broken resistor legs at pre-amp and power amp modules insides, they are the low-value/2-3W rated and the soldered legs broke so easy because of enclosure vibrations, let me know a bit more to improve help...
Nov 04, 2013 | Marshall Amplification Marshall JMD1...
I have a marshall mb150 and sometimes it used to stop emitting sounds for a while but now in the sounds gets deemer and louder every now and then
A common issue with Marshall Amps are generally speaking a low resistor value cracked leg inside the power module, just open up the amp and with the amp unplugged from mains check by a little finger movement the big 2/3W resistors and possibly you will find that one or other will have a broken leg, also cold solder joints do this kind of issue, hope this helps...
Oct 09, 2013 | Marshall Amplifiers Marshall MB150 150W...
Need to identify and find parts for the Pearl FZH725/C85 Drum Kit. It was delivered with missing parts. Specifically Floor tom, 14" tom and arms to hold it. Need some direction and guidance, thanks.
I am a drummer as well in a classic rock band. Most the time when I need a part for something for my drums. I will go to guitar center. But to save money eBay is your best bet. You go to guitar center to make sure you have the right part, but don't buy it there . Match it up and go to eBay, lot of drum companies use eBay to sell there stuff. Thanks mike
Jul 22, 2011 | Pearl Forum FZH725/C85 Drum Kit, Zenith...
Sk 100 body pack transmitter does not seem to be transmitting. Red or Bat light stays on constantly even with a new battery installed. Any quick fixes? How about schematics? Dan
Reading the instruction manual, the red LED is used for more than one thing. I suspect the unit may be either not synced with the reciever frequency chosen or in one of the mute modes. I would re-read the setup mode for this unit as the SK 100G3 is a bit more complex than many for setup.
If the light won't go off when you open the battery cover and press the button to turn it off following the procedure, then there is a problem. I would go through the COMPLETE initial setup of the unit from scratch. Schematics are non-existent for most of this and would not do you much good anyway as the circuit boards will all be surface mounted with some parts the size of a grain of salt. Also a lot of the RF will be under soldered on shield covers. Repair of these would be a factory job if they even do it. If you have ever opened a cell phone, that will be comparable.
May 08, 2011 | Sennheiser SK 100 G3 Mic Wireless UHF
Problen on BDI 21 pedal all OK run normally with battery, but if plug ac adapter is death ? any sugestion?
The adpater should be a 9 volt DC with at least 50 ma capability. The center pin of the connector is the negative. The connector needs to be a 2mm size. Please note that some adapters have a center hole too large and fail to contact.:
Mar 09, 2011 | Behringer V-tone Bass Bdi21 Pedal
How do you replace the adaptor jack on a Casio WK-1200 keyboard ? is it easy ?
Unfortunately the adapter jacks are a bit of a weak point on many keyboards but it is quite seldom the jack socket itself that is at fault.
Often the sockets are soldered directly on to the printed circuit board and are prone to either one of the soldered legs breaking, or even the circuit board itself cracking around the jack socket.
Whilst it is generally possible, with care, to resolder a broken leg on the socket if the actual circuit board has cracked the whole board will have to be replaced.
If the actual jack socket itself is damaged it should be possible to snip through the legs and remove it before soldering a new one on to the stumps of the old legs. this is likely to prove easier than trying to solder directly onto the circuit board, unless this is something that you are experienced at doing.
Apparently you can purchase a full service manual for the Casio WK-1200 here for a modest price but I have not used this source myself so cannot vouch for how good it might be.http://www.tradebit.com/filedetail.php/2084335-repair-manual-casio-wk-1200-electronic-keyboard
Feb 02, 2011 | Casio Music
Pot broke off
Use an ohmmeter to read the value. Even if the resistance element has been broken you can read by touching the remaining part and estimating the total resistance by what is left.
NEXT look for an A or B on the can as this is the taper type. You may also find the resistance marked there like 50K or it might be something like 1003 (100K ohm)
You need to match the resistance AND the taper.
Jan 22, 2009 | Behringer Music
Samson CO3U USB mic pattern selection switch broken
I have not used that particular mic, but have a AKG 414 which offers the same three patterns and there are three distinct and separate settings on the switch. Maybe take it back into the store where you bought it and ask for clarification there? Hope this was helpful. Peace
Dec 24, 2008 | Samson Audio C03upak Co3u Microphone with...
Music Logo
35 people viewed this question
Top Maxon Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Maxon Music Expert? Answer questions, earn points and help others
