Question about GE Cameras
Camera does not turn on
Camera was working fine batteries went low put it to charge and when tried to use it again camera wont turn on anymore ..... just got it about a week ago
  • Rosa Trevizo
    Rosa Trevizo Dec 30, 2013
    Hi Rosa Trevizo, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? okay so its a ge digital camera model g100 what else do u need to know ? thank for the help
  • Rosa Trevizo
    hope u got the information I sent had never used this website sorry
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 575 Answers
Some problem have
Posted on Apr 06, 2017
    Top Expert:
  • GE Master
  • 6,702 Answers
Rosa, I think the only thing you did was get out the batteries and tried to charge them and then jut put them back in the camera.
Only a few things could have gone wrong.
One or more cells could have died, during charging. It can happen, special with batteries that have a uneven use. Like once or twice a year the camera comes out the box and then the batteries are charged. Even when you don't use he camera, make it a habit to charge the batteries every few months.
Then it could be your batteries are still in good shape and fully charged, but you put in one or more calls the wrong way around.
Please check carefully if all the cells are inserted correct.
If nothing works, and you can't check the voltage of your batteries, try another set of batteries.
Posted on Dec 30, 2013
4 Suggested Answers
iwhitman2055
SOURCE: Olympus digital camera wont turn on
First: thank you, for suggesting battery terminals. It was failing to power on intermittently for some time; the problem became more-and-more frequent until it would not come on at all. Cleaning the terminals saved my camera! Second: for others, let me suggest plain old pencil erasers as a good way to clean electrical contacts (something I learned from HO model railroads as a kid). A vigorous rub with the brand new eraser on the end of a pencil cleaned the battery contacts inside the camera.
Posted on Jul 29, 2006
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch the positive (+)end of the 9v battery to the positive (+) end of the camera battery.Leave them touching for a few seconds (10 seconds should be more thansufficient). Seems these lithium-ion batteries are subject to a'digital memory.' Subjecting it to a volt surge almost three timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
Posted on Oct 01, 2008
  • 3 Answers
SOURCE: SONY CYBERSHOT DSCW-5 PROBLEMS..
I had The Same Problem!
I talked to sony and They Gave me a solution.
Reset The Camera!
To Do This
Turn on the Camera (So it stays on at least)
Press The Menu Button
Go down to Setup 1
Go to Initialize
There should be a menu that says Cancel or Ok, press ok
Turn on the Camera
and It worked for me =)
Posted on Jan 04, 2009
My one camera wont work anymore
Check camera charger output voltage with multimeter. If there is no problem with charger; charge camera battery to full charge. As a next step; check your camera battery voltage with multimeter. If battery is dead, replace battery with new one.
Nov 17, 2014 | Uniden Wireless Video Security Camera...
Can't open the lens and it's always low battery
It would appear to be the battery or the battery contacts. Clean the contacts on the battery and recharge the battery. If still does not charge then get a new battery
Dec 17, 2013 | Olympus Sz-12 14mp Wide-angle With 24x...
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Samsung WB550 Digital Camera
Wont go to picture taking screen or playback menu
A lot of cameras seem to be having this issue (including myself). Eventually it got to a point where the camera doesn't even turn on properly anymore. Better take it back for repair, STAT before it ends up like mine :(
Jun 29, 2010 | Fuji FinePix J10 Digital Camera
Screen wont come on
Does it only light up when you adapter is plugged in? If so try taking out the battery and making sure it is in correctly. Press the power button under the screen on the side if the unit and the middle circle in the directional key pad, there should be a menu that comes up.
Jun 17, 2009 | Jazz DV-179 Digital Camera
Nokia 7390 wont turn on or charge
hope phone has not had any water in it. try software update via usb cable and nokia pcsuite
Sep 07, 2008 | Nokia 7390 Cellular Phone
Svp t-100
lol u have to put the card in before u turn it on... most cameras do that...
Aug 13, 2008 | SVP HDDV-2500 Camcorder
My camera doesnt work.
i suggest that there is likely a motherboard fault or a board fuse has blown. the fuse needs to be replaced by a qualified technician, this will prevent any further damage to motherboard.
Jun 07, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Battery problem or camera problem?
A new battery should help you to solve this problem.
Aug 07, 2007 | Casio Exilim EX-Z57 Digital Camera
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Aug 05, 2007 | Nikon D70s Digital Camera
Cameras Logo
173 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
